What's your sulfur substitute?
CARC686
706
New Mexico
A quart of house brand chainsaw oil per about 20 gallons of fuel keeps my injector pump happy and the pump lets me know when the fuel gets too dry. Starts bogging and surging.
Anybody running marine two stroke in their Stanadyne?
Looking to buy cheap lubricity in bulk. Still haven't figured out a preferred solution. I had been getting quarts for about $10 at the nicest gas station in town, but they aren't reliably stocked, and subbing four stroke oil in a pinch does not help at all.
Would try biodiesel if it was commercially available in my area, but near as I can tell, it is not. Probably for the best, since I don't have the first clue where to find biocide and I'd probably end up brewing diesel kombucha.
Anybody got a solution to this issue for less than ten bucks per tank of fuel? Especially if it can be bought in buckets or drums?
Ten bits
Portland, Oregon
Here in Portland, OR we have R99 (99% renewable diesel). My full stock M1028 with 80,000 miles runs well with it. Prior to the change pump diesel here was B5 or B20. My truck ran fine on that also. There is a station in town that sold B99. It now sells R99. When it had B99 I would fill up occasionally with it. My truck ran a lot quieter with B99 and I think the throttle response was a little better. It also smelled like french fries.
I only use a fuel additive in the winter for easier starts. The one I use is Power Service Diesel Kleen with Cetane Boost.
I've had this truck since 2007 and put just over 50,000 miles on it. It is my Daily Driver, and gets mostly light use (no towing). All I've done to it is routine maintenance and replaced rubber seals and hoses.
CARC686
706
New Mexico
We haven't got biodiesel here. I would suggest to city counsel that we have one biodiesel station per 500 head shops, but the city couldn't sustain that many biodiesel stations.
87cr250r
2,121
Rodeo, Ca
Nothing. I have 52 engines accumulating 2500 hours a year each and we are not experiencing any failures with regards to fuel lubricity. We run R99 which is a hydrotreated vegetable oil fuel. I had low hour 2 injection pump failures under warranty on MTU 4000 engines, 2 injection pump failures on Cat C9.3 engines at ~18,000 hours, 2 injector electrical failures on the C9.3s, and have had two injector failures on John Deere engines, no solenoid alarms but no fuel injected either.
We had performance issues on our larger engines so I did the calorimetry on the R99 and it was within 1% of the test diesel used by the engine manufacturer to certify the engine.
There may be complications with water separation/bacteria with the R99. I'm seeing dirtier filters now with the R99 but that isn't true for all of my vessels so I can't correlate the problem with the fuel.
P.S. on the MTU and C9.3 pump failures only a pump replacement was required, no injectors. The nightmare stories all circle around Bosch pumps which none of the engines in my fleet have.
CARC686
706
New Mexico
I don't mind short filter life. Seems this truck has to be overhauled every six months anyway. If it had to be reliable, I'd drive a Toyota. If you'd like to ship me a few dozen drums of R99, I'd stack them up out back. Probably the only way the CUCV will ever get any. I'm never going to clog my fuel system with a SCOBY using the local ultra low sulfur highway diesel. At this point, I'm just glad I don't have to know or care what DEF is.
nyoffroad
737
Rochester NY
Not a thing, I have several million miles behind me in various trucks and the only time I've added anything to the fuel was 2 times I needed a biocide and once I had an ice slushy build up around a fuel filter and it started to freeze up, a dash of 911 (red bottle) and back on the road.
I believe most truck IP's will suffer from old dried up throttle shaft seals long before the pump wears out due to lack of lubricity. Adding an oil to oil never made sense to me.
53
20
NC, USA
millions of miles with a modern truck, or one designed when diesel had more lubricity?
CARC686
706
New Mexico
You used to be able to wash the sludge out of a gasser by putting diesel in the crankcase. I wouldn't dare these days.
87cr250r
2,121
Rodeo, Ca
EMD, large railroad engine with design dating back to 1938, specifically warns against flushing engines. The sludge deposits in places where it does not harm and flushing can dislodge the sludge so it can do harm.
87cr250r
2,121
Rodeo, Ca
It's still in production today.... The same project manager that developed the EMD engines went on to develop the 71 series Detroit Diesel. Everything they did is present in the most modern engines. Otherwise, modern oils mean fewer deposits but if you've got them it's best to keep them where they are.
I thought we were agreeing with eachother?
53
20
NC, USA
Just stating some facts, while at it I'll ask a question. How many IP's are out there on running engines that HAVE NOT BEEN REBUILT SCINCE 198WHATEVER? Rebuilders do improve parts as does the OEM.
no clue......
But is those millions of miles in a newer diesel with a modern ejection pump as I had asked? Or millions of miles with a old db2 injection pump, with ULSD where as ULSD did not even exist yet?
Answer: No.
Many do run a 2 cycle oil in these old dogs to protect the pump, due to the very known lack of lubrication in ULSD. I do, and the truck run noticably better with it than without.
The notion that no adding a lubricator to the fuel is a bad notion. It can only help, if used properly.
muthkw25
740
Canton, PA
For lubricity for your pump, I use either optilube or Hot shots. both companys have products for just lubrication that's vastly superior to 2 stroke oil. Optilube had studies that show how much better it does over alot of other competitors in an independent lab study. Hotshots is a newer additive and is also great for lubrication, preventing rust, cleaning, cetane, etc.
