mep803a fuel pump not clicking
asulwer
Williams, Arizona
i think that the fuel pump is bad. ran the generator last night for the first time in a couple of months. after a few minutes of running it turned off. i went through the section 5 - troubleshooting 2-11 in the technical manual, specifically "cranks but fails to start".
the fuel pump is the old square kind. purchased a new round one. when the S1 switch is in prime/run i can hear the pump making a high-pitched noise, not the usual clicking.
IS it possible that something other than the pump is bad? something i may have overlooked?
WWRD99
1,912
York Pa
You can put a dvom on the connections for the fuel pump and see if any power is getting there. The old hit it with a hammer and see if the regular ticking noise returns is a good way too. I've found many problems with a light tap on things in the past.
asulwer
Williams, Arizona
yes it does receive power. if i rotate S1 on/off a little squirt of fuel comes out of the disconnected hard line on the pump
WWRD99
1,912
York Pa
Here's a pretty good thread on finding a pump.
Ray70
7,010
West greenwich/RI
Even if whacking the pump gets it going again, do yourself a favor and get rid of that Facet Cube pump.... it's guaranteed to let you down at the least opportune moment!
I'm actually a bit surprised it quit on you during a periodic test..... usually they wait for the start of an extended power outage to crap out! ;)
asulwer
Williams, Arizona
The thread link above recommended two pump replacements. The original Facet 40193 pump broke and the Airtex E1074 found on newer models cannot be found, according to the thread provided above.
Airtex E8131 (renamed to Carter Inline Electric Fuel Pumps P74018)
Airtex External Electric Fuel Pumps E8135 renamed to Carter Inline Electric Fuel Pumps P74016
i purchased a clone off of amazon Airtex E8135
no idea what the gph or psi are of either of these two. the clone provided a list of parts the clone replaced
O'reilly: E16208 (their specs list this as 5.5 - 9 psi and 27 GPH)
Airtex: E8135
Carter: P74016
Gmb: 5991460
Napa: B0143e
Onix: Eh135
Spectra Premium: Sp8114, Sp1187
WWRD99
1,912
York Pa
Airtex: E8135
Carter: P74016
Gmb: 5991460
Napa: B0143e
Onix: Eh135
If you dig through that thread it does end up with the one you got. It is 5.5 to 9 psi at 35 gph. It is 24 volt too. At 62$ I think i'd look for a real airtex one.
CallMeColt
1,718
Wilson County, Texas
I have found that the Facet, square pump is said to fail here on the form more often simply because they are on older manufacture generators. I have had about the same fail rate on the AirTex. It really doesn't matter what pump you have, if it is run dry for to long or has a bunch of gummed up diesel fuel in it, it will burn out quick.
I'd take a new Facet, cube style over the China made Carter ones. But again, anything new is better than something burned up or gummed up with old fuel!
I want to make an in-line fuel pressure test kit to check easily if the pump is fading.
