4L80E Trans light, power supply?
justHelpChris
austria
Hello,
i just started to repair my HMMWV.
i have the problem that the trans light is always on,
i checked with the multimeter
#657 with masterswitch is off, there are 4.7V
the Relay is working correct, 12V on run, 0 at off
i also have always 5V at the TPS sensor, even when the engine is off, normal?
if i disconnect the TCM (J1), than i have not the problem
so,
could be the problem that it is the wrong TCM??
i have the 6.5liter turbo
tcm with eprom
i hope somebody can help.
greetings from Austria ;)
Mogman
10,602
Papalote, TX
You need to check 290C/291C (connected to trans relay) to make sure the trans relay is releasing when run switch is off.
justHelpChris
austria
as mentioned above the relay release correct!
without tcm,
i have alle the 12V when turned on at 290/291/810/657
and 0V when turned off
when i connect the J1 from TCM
i have 12V when turned on
and 4.7 when turned off at 290/291/810/657
does the TPS always have 5V even when Turned off?
Mogman
10,602
Papalote, TX
By the way, Welcome to the SS forums!
I do not believe you should have 5V at the TPS when off, it looks like you have a defective TCM.
It seems you have done a thorough job of troubleshooting the issue.
All HMMWV TCMs are basically interchangeable only the shift points are a little different between the turbo and NA engines.
justHelpChris
austria
i think i found the problem,
inside the TCM, i have a popped ceramic capacitor
anyone can read the the numbers on it? or can tell me the size?
maybe i can repair
Milcommoguy
2,431
Rosamond, CA
My guess is that is a varistor. Used to clamp a design voltage based on the part number not seen in the photo. I don't have a TCM to look at so maybe the boys here can verify.
Just a guess, CAMO
Mogman
10,602
Papalote, TX
I am not sure I would condemn it based on that small black spot, if it is bad it should measure as a dead short .
MOVs are protection devices that are insignificant in the operation of a device, to say you can cut it out and it should not affect the operation only that circuit will not have any over voltage protection.
justHelpChris
austria
i had a short on the PCB,
and the varistor showed only a few k-ohms
now i have another question,
when i accelerate,
and it wants to shift into the next gear,
it shifts up briefly, then immediately back down again or feels like neutral, the engine howls (1-2sek), and than into the next gear.
i think this only happens in gears 3 and 4, however.
could be the problem i have no break switch installed??
