How does dual switch brake pedal work ?
Mastherr
17
Miami, Florida
Folks, I was finally able to do the testing. I disconnected the TOSS and went for a drive…. Terrible performance ;-) Than I reconnected the TOSS and disconnected the TISS, went for a drive…..
Stopped and performed the transmission code testing…. And NOTHING!!!! No codes stored…. Again 1,2. 1,2. 1.2. 1.2 ………
I hate to get to this conclusion, but I think the problem is with the TCU, correct?
Your input is much appreciated.
Mogman
10,404
Papalote, TX
I do not think the TCM stores codes, so the TOSS may have cleared when it was reconnected, the supplement should describe what clears the codes (besides disconnecting the batteries)
It does seem to point to a TCM issue.
IIRC some codes would clear when the vehicle was shut off and re-started if the condition was no longer present.
Mogman
10,404
Papalote, TX
I do not know of any specific test you could do to prove the TCM was bad but lets recap.
1, You can put the TCM into diag. mode so the TCM is getting both sources of power it needs to work. (continuous 12V and switched 12V)
2, You can disconnect a sensor that should set a code and turn on the trans warning lamp but it does nether.
If you unplug the TOSS and drive the truck to at least 3000 RPM you should get a code 24 TOSS circuit low.
I am sorry, I used to have a loaner TCM I would send out but I had to use it on a build so it is no longer available.
Mastherr
17
Miami, Florida
Thank you Mogman, for your offer, appreciated.
Question: would push to 3,000+ RPM on limp mode be advisable? Is it ok to force it that much to try to generate the code for testing the TCM?
if anyone else has a TCM I could borrow for testing before spending $600-800 on a new one would be great…
Mogman
10,404
Papalote, TX
If it is in limp mode and the trans light works you should have codes if the TCM is good, you should not have to run it hard to get a code.
