Moving Tachometer from a REV M1165 to an ECV Truck
GMVguy
112
Texas
What would be involved in moving the windshield-frame-mounted tachometer from a REV truck to an ECV M1165A1?
DREDnot
584
Phoenix, AZ
You will have to modify the #2 wire that comes off the regulator to add in the tach harness. Its actually easy to do. There in instructions that come with a tach kit. I cant find my pics of it at the moment though
KKroger
157
KC MO
Ring terminal on the Tach Harness goes to the AC term on the reg (presuming 200/400) then you take the existing ring on the body harness and put the proper packard plug on it and plug it in. the other two packards connect in line with the Fuel Sender wiring IIRC... there is no light so... I have the print somehwere.
