Installing back up lights on the Humvee
McSpeed
293
Palmer, AK
Awesome!!! I ran 12 volt back up and rear door lights. Had the 12 volt power that goes to my trailer relays and signal wire installed already. Only had to unplug the factory 24 volt connectors to my wires and BAM!!!
JoeJrTheBarber
21
Chicago, IL
I ran similar LED clusters / pods inside my bed for lighting. his way when i lower my tailgate the lights come on like a modern pickup.
Had to run two dimmers (one dimmer = 2 lights) as they were so bright it was like a concert hall in my bed of the truck ! will post pics soon
when i get my truck back and can take some pics..
65grendel
12
Florida
I did the same thing to my 1988 M998.
I bought the same switch as the above but for whatever reason I already had one in my shifter ?
So I wired that to similar lights and bam we have backup lights.
View attachment 750978View attachment 750979
I also added a small (but super bright) light bar under the back bumper angled towards the street that comes on along with the two backup lights
when the truck is put into reverse (as well as the backup camera too). I did this on a old lifted Jeep Grand Wagoneer I had and I cant tell you how
easier it makes parking these trucks at night when you can actually see.
Should of been a AM General factory option !
View attachment 750980View attachment 750981
that’s an awesome idea!
Mogman
10,439
Papalote, TX
Not to resurrect an old thread, bit it's pretty spot on. Will this kit allow me to tap into the transmission for the backup lights or do I still need source the 3/4" thread adapter bushing? Thanks.
The minimum you will need are these parts, the adapter and the switch, the switch is the same as the neutral switch which cost less than half of what most are trying to get for a "reverse" switch, you can get these off of fleabay for around $90 total, which is still too high IMHO....
TOBASH
3,913
Brooklyn, NY
View attachment 950134View attachment 950135
just sayin’.
