Fan Time Delay Module bypass / Manual Fording Switch
dherman304
61
Texas, DFW
My TDM went bad and I'd like to bypass the TDM and possibly build a manual Fording switch that turns off the fan. Before I recreate the wheel I was wondering if anyone has done this before?
Also, I'm well aware if the military or designing engineers wanted a manual switch they would have installed it but for the typical home-gamer it might not be a bad idea.
Mogman
10,439
Papalote, TX
This is how I would do it, I added a diode to protect the relay contacts, it should be a 1000V 1A (1N4007) diode.
It is a little sloppy, sorry...
I would use this relay, and of course carry a spare, this relay is "protected" meaning it protects the fan thermal switch against reverse EMF, paying attention to the terminal numbers is important.
Yes it is CHICOM but at least it carries the HELLA name.
Retiredwarhorses
4,563
Brentwood, Calif
You don’t need a TDM as the thermostatic switch allows and denies 24’s anyway to the TDM, the TDM is not what actuates the fan, it’s the thermostatic switch Wired to the Cadillac valve solenoid.
Mogman
10,439
Papalote, TX
The Cadillac valve pulls around 3/4A, I cannot even read the current going through the thermal switch so (must be in micro amps) the thermal switch is obviously not powering the valve directly, the TDM uses the signal from the thermal switch and the kickdown switch to determine to switch power to the valve or not.
I would certainly not assume the thermal switch could live long directly powering the valve, that is why I would use a relay.
If connected directly it would definitely need diode protection from the reverse EMF from the valve.
Retiredwarhorses
4,563
Brentwood, Calif
Huh?
I’ve literally had US military trucks with an adapter that eliminated the TDM…the Cadillac valve is a 24v solenoid, everything electrical is 24v…
24v is present at all time on the engine harness on wire 458 when the key is in the run position
Mogman
10,439
Papalote, TX
Huh?
I was surprised at how little the valve actually drew as far as current, I did not say the thermal switch could not power the valve I just said I would not assume it would and that with the TDM it is not actually powering the valve in that application. I would love to get my hands on one of those "adapters" to check it out, you can hide allot of stuff in a molded plug.
I would still use a relay, they draw around 30Ma which is around 20 times less current than the valve and in its original configuration with the TDM the amount of current the thermal switch is switching is virtually nil.
The current a switch has to make/break is far more important than the voltage although the voltage does dictate how fast the contacts must separate and how far.
I have had no luck finding any actual electrical specifications for the thermal switch.
Retiredwarhorses
4,563
Brentwood, Calif
dude, this is 70’s technology….stop over thinking it.
Mogman
10,439
Papalote, TX
It is actually much older, the FET (which obviously the TDM uses because of its low drive requirements) was developed in the mid 40s, the solenoid controlled valve in the early 1900s and the bi-metal strip used in the thermal switch is at least 200 years old.
I cut my teeth on this stuff in the late 60 and 70s, in the 80s I was a component level technician and in the 90s I was helping develop circuits and components for SCADA systems, so yes maybe I do over think things a little.
But if you by-pass the TDM and drive the valve directly and have no long term issues with it then I concede.
