IP timing
USN_Green_Addict
227
Oahu, Hawaii
After having the worst time trying to get my newly bought LDS pump on my LDT motor I decided to compare TM on just this. It appears there is a small difference from these two in regards to the HH scribed tooth being one of to the rear or just being visible. What's the deal? And what is the most accurate?
  • Like
Reactions: HDN
Floridianson
2,538
Interlachen Fl.
One of the pages of the TM you showed is when we replace the whole IP and how to set it up. When first installing the IP to the engine the timing is not going to be correct. The other is showing corrected timing with harmonic balancer on its Mark the advance window on its Mark and the head approximately one tooth to the rear. So bottom line is when we install the IP to the motor the harmonic balancer will be on its correct stroke and Mark. The advanced timing window will not be on its mark and the head red scribe will be on its mark but and visible. Then we correct the timing by rotating the center bolt on the drive gear and bring the advanced window to its mark and tighten the three bolts for the drive gear and the head should be approximately one tooth to the rear.
Barrman
2,232
Giddings, Texas
I just got done playing with this for a video that will publish this coming Friday. The link to my channel is in my signature.Everything is post 2 is spot on.
The balancer line and the pump line under the 4 bolt window need to be exactly lined up at the same time. Then, the red tooth will be 1 tooth to the rear of its pointer. The red tooth is for lining up the hydraulic head for removal. That is when it needs to be one its pointer. Not, for timing the engine to the injection pump.
Floridianson
2,538
Interlachen Fl.
IThe red tooth is for lining up the hydraulic head for removal. That is when it needs to be one its pointer. Not, for timing the engine to the injection pump.
While you are correct about the red tooth being on the pointer for when we are only removing the head it's one of the three timing marks on our engine. If the injection pump has never been disassembled and the head removed and install correctly then there should be no problem. Just because we line up the head pointer and the quilt shaft cut out for removal the head itself can be dropped back in off scribe mark. Also the TM has us when installing the injection pump to the motor the head red scribe mark and pointer should be lined up. After install that's when we correct the timing using the center bolt and slots in the drive gear. That's why it's always good to double check everything or someone's mistake.
