Glow plug solenoid wiring
OccRzr1775
Santa Clarita, CA
Sorry I looked for a thread related to this and I can't find one for my problem with my M1009.
Took photos before I detached the old glow plug solenoid and now I'm seeing two extra wires that I did not see before and I'm not certain where attach that.
Photo below. Shoot the two wires not connected in the bottom left. I'm thinking the red to the top of the solenoid and is that other a ground should to go on to the firewall?
Here's a picture of how it was wired before
I'd appreciate anyone putting him in the right direction of where I can find an answer for this.
Thank you
Sharecropper
1,294
Paris KY
Here is a fresh photo of my relay. I had previously removed the glow plug resistor and can't remember if that procedure required any of the wires to be moved. Hope this helps.
deank
694
Inverness, Florida
Here is a copy of the colorized wiring diagram. I have circled the glow plug relay so you can trace all the wires for an original setup.
Tinstar
2,624
East of Edmond, Oklahoma
Recommend that when you splice in new wire to an existing wire, use the same color wire.
Adding yellow wire to the end of a red wire, etc will make things very confusing down the road.
Your before and after pictures show at least the blue wire location placement.
