HMMWV M1123 FLASHER UNIT WIRING
4x4nutz
133
Mico, Texas
Someone managed to cut off the plug going to the Nartron flasher unit on a build I am doing for myself. A friend and I both looked on the schematic and could not find it so I can rewire the unit without burning it up. The identification number tags were on the other side of the cut, so I have no idea which wire goes where. I also searched everywhere for info on this without finding anything. If you can help me figure it out, or guide me to a TM on this I would be eternally grateful .
Mogman
10,469
Papalote, TX
It is right there in the schematics, 325A goes to pin H on the turn signal control unit (switch) , 325B goes to pin F on the control unit and 57K goes to ground.
4x4nutz
133
Mico, Texas
Thank you Mr. Mogman...I could not find it. I bow to you Sensei ! When are you coming to visit again?
Mogman
10,469
Papalote, TX
Any time you need me to, I am bowed up like a cutting worm right now, clearing an area for several conex boxes so I can clear out my shop and a buddy of mine just bought a drilling rig and is having towed to my place so I can put in the 10" cased well for the 16' Aermotor, of course I have to rehab the rig first :LOL:
Mogman
10,469
Papalote, TX
Is 57K going into the plug a ground or the power?
Just ohm out the three wires going into the harness to ground with the wires unplugged from the turn signal switch, it will be the only one showing around 0 ohms, then ohm out the other two to the turn signal plug terminals F and H
4x4nutz
133
Mico, Texas
Any time you need me to, I am bowed up like a cutting worm right now, clearing an area for several conex boxes so I can clear out my shop and a buddy of mine just bought a drilling rig and is having towed to my place so I can put on the 10" cased well for the 16' Aermotor, of course I have to rehab it first :LOL:
Sorry. Hope your better soon. My right hip has been killing me...so I am close to having the surgery I think...water or oil rig?
Mogman
10,469
Papalote, TX
Water,,, oil? I wish, I would like to see an Aermotor pumping oil, that would be cool!
Although this will be pretty cool, with a 8" cylinder in a good breeze she will make around EDIT, sorry it would be 55GPM, still allot of water!
