Turm signal issue
oakley1919
Indianapolis, Indiana
Im hoping someone can help me with a turn signal issue on here.
1986 M1008.
When the parking lights get turned on the light for the turn signals left and right also turn on. Hazards work fine on their own and flash alil fast. Neither turn signal works on their own. Ground is good bulb is nice and bright.
It's like the parking lights are back feeding into the turn signals with how bright the lights are but they aren't flashing and the turn signals won't operate.
BTW both turn signals worked last week.
Items replaced:
Turn signal switch under the steering wheel.
Front turn signal bulbs.
Front left and right turn signal pigtails replaced due to broken ground in the socket.
Light bulbs in dash.
So at this point I'm kind of lost as to where to go next.
Any help is appreciated. Thank you all.
deank
642
Inverness, Florida
Please check and or replace the side marker bulbs and the rear stop/tail/turn bulbs. They all act as turn signals. The indicators on the dash stay on when there is a bad bulb in the circuit.
