Differential
20,698
Hi friends, what kind of oil seal do you use for the differential carrier? I don't want to give it N.O.S.
So... On a Deuce... Guessing that you should be able to remove the seal without wrecking it? Hopefully you can see the part number on the seal - then start searching the web for a replacement?
I was a little disappointed that the Deuce Parts List didn't have one listed. I would take the seal to a truck parts house just to compare it to what was in it...
