mep 802a engine side top part# 88-22013 roof per tech. manual 24p
yeller 1
23
Auburndale,Fl.
Looking for a camo engine side top panel , anybody got one for a Mep 802a part# 88-22013 roof per 24p manual
yeller 1
23
Auburndale,Fl.
still looking for a mep 802a top panel that covers engine compartment , seems like nobody has one,any help from my fellow brothers would be greatly appreciated, bump
Guyfang
26,877
Burgkunstadt, Germany
"Engine Side Top." Not a real clear explanation of what you want. Might be better to post a picture out of the -24P and tell people what Item number it is.
yeller 1
23
Auburndale,Fl.
thank you for your support, part # 88-22013 roof is the part number from tech manual 24p,need one badly as the one is missing
thanks in advance to you
yeller 1
23
Auburndale,Fl.
Thank you for your help, i really appreciate it, thought it would be here cause there are so many of them around and this site is just always been so helpful . thank you again guy
Light in the Dark
6,745
MA
I had 3 of them 6 months ago that had been sitting here for a few years, went to a local Vietnam vet scrapper with some seized blocks, skid bases etc earlier this spring :(
yeller 1
23
Auburndale,Fl.
I am still trying to somebody somewhere that has one , I am not looking for a showcase one just one to keep the rain out of my unit, anybody, please give me a shout.
Toolslinger
299
PA
Wish I could help ya, I've got one for the 803/813 units, but too big for you...
You might keep an eye out for a complete clapped out unit (802a, or 812a). I picked up a 813a carcass just to get the wire harnesses for use on my 802a. It was a wealth of spares, and the balance of the parts are slowly being sold off to recoup the purchase cost, which was minimal since the engine, and gen head were already out of it...
yeller 1
23
Auburndale,Fl.
Thank you for your reply and I appreciate it, it’s been really hard trying to find one really didn’t think that it would be so difficult as there was so many people with the units and non runners out there and again many thanks for your reply. Just in case you know of anybody who has one please let me know
LuckeyD
264
53
Vilseck, Germany
Top Roof 5KW. This one took several hours of squinting in thousands of tech drawings and several versions of the tech manual for parts dating back 30 years. We found one part number in both 5 and 10 KW manuals the same and a 5KW is shorter. one is 3 inches or so longer The best we can figure Part Number 88-22013K001 attached should be the right one from a 1996 manual and I even helped put that in there, DUH. We also had to figure on distribution codes which some folks watch what is put out. The cover is a bit longer than 27 inches. Please measure on your gen as I have nothing but a computer and an old memory . I provided PN 88-20013M001 earlier but this is for one of the box lids as I was pointed out. The 2 instead of a 0 makes the difference and the files use only a portion of the entire part number. I have a small screen too and eyes are not so good as they used to be. So you have a roof a bit over 30 inches in the 2035 drawing and one a bit over 27 inches in the 2013 drawing. Measure and see which you need. These are AutoCAD drawings set up to use a program called Bentley view and I wrote a script to get a PDF monochrome you could read. Oh yeah, lots of fun.
yeller 1
23
Auburndale,Fl.
I think I will see what the sheet metal shop will have to charge to make maybe a couple of them in case of others may need one.thank you for your efforts to help us out. I have been looking high and low for one. Many thanks again for all your efforts.
