Coolant came out of Cylinder Head when removing Glow Plug
LTHumvee
Nevada
Obviously this is a problem and my first thought is that I need head gaskets and possibly head work done but I a not a mechanic by no means. Has anyone else had water drip out or pour out of your cylinder head when removing a glow plug?
NDT
7,499
Camp Wood/LC, TX
More info needed. Is it water or antifreeze? Have you been driving your truck around and then this happened? Did you just win this at auction and the air horn was removed, allowing rain to enter the engine?
LTHumvee
Nevada
I have put around 6000 miles on the HMMWV since it was purchased and it had a new GEP Engine installed just before I purchased it. 2006 1152A1 for reference, 6.5 Turbo 4speed. When this happened, I was driving about 45 MPH and it suddenly shut off on me. It was unexpected when it shut off, and when it happened I looked down at all gauges to see what happened and all was well except engine temp was in the yellow. I let it cool off, I added about 1 quart of Ozarka Water from the gas station I rolled into when it shut down, checked oil for water, etc., and that was all good. I tried to start it, it would not start, so I called a tow truck. Since then I have checked fluids once again with nothing abnormal found except a bit low on Antifreeze but during diagnosis and trying to start it, I found the starter drive was fried. I did the work around on the starter box to see if it would start and drive and it did start up. I started it 2 times within an hour and decided to drive it since everything sounded good. It felt ok at first when driving except I felt what felt like a misfire so I immediately turned it around and went back towards my house. I saw the temp was getting hot so I shut it off for about 10 minutes and then it started up and made it home. I was only a few blocks away. When I got it home, I let it sit overnight and tried to start it the next morning. It acted like it wanted to fire up but would not so I started checking everything. I pulled the passenger side, rearward most glow plug and a water/oil mixture came out of the cylinder head. It was more water than oil but a large amount came out of there and also a watery mess came out of my exhaust when trying to start it. To add, I pulled the drivers side rearward most glow plug and no water came out. I did have one of two glow plugs not show any resistance and they are the oem glow plugs.
KKroger
225
KC MO
I'd do a compression check and or Leakage check on that cylinder and see if the adjacent cylinder has the same issue.
Hope it didn't hydraulic lock...
LTHumvee
Nevada
Will do and planning to do so today. I am able to rotate the engine using a wrench underneath and turning my Torque Converter. I don't think it hydro locked but will know for sure. It did turn over but would not start again so there is hope.
87cr250r
2,137
Rodeo, Ca
Is it smoking when you crank it? It doesn't take much water to make a diesel engine not start. I had some Cat C9 engines that would regularly get water in the intake from failed aftercoolers. When I wasn't able to be present the dealers would tell us the engines needed to be overhauled for $40k. After they left we'd dump a can of starting fluid in the intake to get them started which would clear the water out and they would run for thousands of hours or until the next aftercooler failed.
LTHumvee
Nevada
It would take a minute to produce a puff of black smoke when cranking that would go away immediately. When the issue happened the final time I did notice some white smoke.
LTHumvee
Nevada
The fluid that came out was weird. It was pretty much translucent and oil mixed together. It really didn't have a smell either. The water and oil was separated but together if you know what I mean.
Mogman
10,563
Papalote, TX
When it died the first time was it "sudden" as in the engine seemed to seize all of a sudden?
Then when you tried to restart the engine would not turn over (rotate)?
If so it probably did hydro lock and you likely have a bent rod.
LTHumvee
Nevada
It all of the sudden shut off while driving the 1st time. It turned over just fine after that happened and started after I messed with it for bit. I then drove it and it started running rough and hot on me. I limped it home under engine power making sure it didn't over heat. I then let it cool down, checked fluids, and then pulled a glow plug and found the water/oil mixture. I have since had more condensation leak out of that glow plug hole and put the glow plug back in it.
