MEP 804A fuel tank floats
grywitt
145
Nm
So a while back I had posted about my low fuel float not consistently working. The nice thing on these is open is good so unplugging the floats means you can run. I hadn't been needing the gen anyway but it's nice to know.
I ordered a new float set up from liquid level and received it and put it on the shelf. Last time I went to run the gen it worked okay so I thought maybe it had resolved it's self. ( right ). Today i decided to exercise the gen and it fired right up and was running good at full load about 10 minutes then shut down for low fuel.
I decided it was time to go ahead and put the new floats in. I opened the package and the floats seemed huge. Sure enough they wouldn't go in the tank. I decided to see if the floats from the original would work on there rod. They did I think since my floats are so much smaller the level at the bottom might be a bit higher when it signals empty but it works.
The other thing that liquid level couldn't make happen is the big gap on the top float so the pump basically runs like it's the primary pump. It keeps the tank plumb full. I got the top float a little high. It's right under the top of tank. And it runs for a little bit then shuts off for just a minute or less. No problem really the primary fuel pump on the offer gens runs the whole time.
I did ask liquid level if they had smaller floats they could send me and they say they can for $10 each. It's my fault for not making sure they had a size to work with. Anyway just a follow up and FYI. I'm happy to have found a replacement. The bad switch is in the tube. Today i couldn't get it to open no matter how I moved or rotated the float. I did think I had fixed it a couple times. Thanks for all the support.
grywitt
145
Nm
I'm still learning how to use these and now that I think I'm doing it correctly I am liking them more and more. They are solder connectors i had been using to low of heat before so wasn't impressed but now they seem pretty good. You can get them on Amazon. I'm still trying different brands so I don't know if this is the best one. I don't usually try to scrimp on things like this. Anyway if you get some and use them go high the heat and you will see the solder melt.
I had friends with boats in Hawaii and they told me about these and said they were awesome.
2Pbfeet
1,447
Mt. Hamilton, CA
Thanks. I like them a lot, too, but sometimes have trouble finding ones that I like. I have had trouble in the past with versions that the plastic split about the time the solder was melting, which is why I asked. I try to find ones that have adhesive inside as well to seal out the elements, having had to deal with marine wiring in the past.
All the best, 2PbFeet
grywitt
145
Nm
Thanks. I like them a lot, too, but sometimes have trouble finding ones that I like. I have had trouble in the past with versions that the plastic split about the time the solder was melting, which is why I asked. I try to find ones that have adhesive inside as well to seal out the elements, have had to deal with marine wiring in the past.
This brand so far seems pretty good. I think that's why I'm starting to like them. Ha ha.
grywitt
145
Nm
Nice job, and I lIke your butt splice connectors! What brand are they and where do get them?
Here are the expensive ones that had me not liking these very much. Like a said i might have been doing it wrong. I bought these thinking they would be a good product and wasn't liking my results. I'll try these again and see if it was me or the product. They have the adhesive lining which i try to always have when I use shrink tube.
