- 831
- 227
- 43
Thanks so much for the tips, now that you brought that up I think that I may have done that originally with the line. Also the rod didn't fall out this time, I even felt in there a bit and didn't feel anything. But I thought it was just my memory crossing over to something else I had worked on.I got the answer to getting that steel line on...don't tighten the pump to the block...just start the bolts and start the steel line at the same time...get it screwed on almost all the way then tighten the bolts to the block. If need be I think there's a stud that holds the steel line tight to the block...can pop that loose too. As far as the glow plug card you don't need to remove the card or do much other than wire a ground switch to the second wire in the gp harness...can get the wait light if you hit the third wire too. Push button in the cig lighter spot.![]()
That pushrod can't "pop out" and go down into the engine can it??
It may have just been stuck in there with some oil build up or something and was enough to keep it from falling out. Guess I'm going to have to take the pump back off now to find out. Which I'd have to take it loose to install the line anyway.
