M54A2 New to me, can't shift it.
Wastelander
Bremerton, WA
Hey y'all,
Been out of the 5 ton world for several years, owned a couple 818's but about to purchase what I think is an M54A2, owner says it's a 68 with the multifuel and whistler turbo. Won't bore you with how much I've wanted another 5 ton so I'll get right to it.
Runs and brakes well, Owner says it can be shifted into gear with truck turned off, and clutch will hold when it's running, but it won't shift without an excessive amount of slamming it into gear while running. He's pretty sure it needs a new throw-out bearing, and after reading a few threads here I'd agree. It needs a few other things but this is the major repair I'd be wanting to tackle right off the bat so it's more or less roadworthy.
What I'm asking here is how similar is the transmission in an M54A2 compared to the one in 809 series? I've got a winch hoist rigged up similar to what I read about in a post from 2009 by 70Deuce, and I assume this truck will be the same process as an 809 series for replacing the throwout bearing, just want to make sure I'm not in for any surprises. Thanks!
G744
4,104
Hidden Valley, Az
Some clutch packages go together with not enough movement with pedal full depressed regardless of linkage adjustment.
I found that with my A1 years ago when a new clutch went in.
I had to lengthen the linkage a bit to get full movement.
G744
Wastelander
Bremerton, WA
G744
I'll check the clutch package and see how it moves before I start tearing into the transmission for the throwout bearing. It just sounds exactly like the same problem I read on another post and the fix was replacing the bearing and pressure plate. Definitely keeping an open mind about it though, thanks!
Wastelander
Bremerton, WA
Sounds to me like the clutch isn't releasing completely.
I'll go over the clutch package and see how it moves before tearing into the transmission for the bearing, it just sounds exactly like a post I read on this forum and the fix was replacing the bearing and pressure plate. Either way doesn't seem like too big of a problem!
G744
4,104
Hidden Valley, Az
It may be the transition from standard facing to VelveTouch (bronze pucks) discs found in service now.
I'm not certain about this. The new TO bearing was exactly the same as what came out.
G744
