anyone tell from pics what generation 5ton ?
sweetk30
horseheads,ny 14845
friend sent me this and asked if i wanted it . he knows the seller and no other info . thanks for any info .
my guess A2 being singled out and hydro steer ram on pass side . but i am not as familur with 5ton . if i had to guess the plans were bob it to 4x4 with trailer suspension and bed behind it .
has not run in 4+ years and told it had noise when running last time . price is cheep even if parted out = make money and semi local and i know a tow truck guy to bring it to me .
cbrTodd
508
Indianapolis, Indiana
It does not appear to have the shackles under the front bumper, which a M923A2 should have. It also looks like the rear axles are the non-CTIS version. I think it is either a M923 that has had super singles added, or a M923A1. The width of the spare tire carrier (whether it fits a super single tire or not) should help determine which one. Either way I think it should be a NHC 250 powered truck.
Side note, the front wheel looks like a HEMTT wheel to me, not a 5 ton combat wheel. Not 100% sure on that but the offset doesn't look right for a combat wheel.
sweetk30
horseheads,ny 14845
so if i wanted to swap a bad nhc-250 and go gas . what SAE adapter would i need to fit up ?
i have a few gm 8.1L v8 motors that run good and would be a good fit for my needs if i bobbed this down to 4x4 specs .
