803A trailer mounted power plant. Lamps
grywitt
245
Nm
These two screen shots are the only place I can find a part number for the on and on line lights on the sync box. I had one wire break off then touch the other side and cause a short and burn up the bulb. The box has spares but they are almost all beat up. I've searched with the part number but nothing pops up and the NSN number that AI gives me isn't for that light. Can anyone help me with any info or a source? The part number 13229E5764-2
XDS1 - XDS4 on the drawing
I can and will use one of the spare lamps that's in better shape if I have to buy it would like to use nice new ones. That bulb showed up as a short on my gen when the wire came off and touched the other one.
peapvp
1,688
Basehor, KS
That still doesn't look right.
Correct, those are not S6S
Someone replaced the original S6S /DC with those. Check and see if the Lamp Code is embossed on those you got. You may need to solicit the help of a magnifying glass.
If they don't have anything embossed or printed on them, then they are finest Chinesium of recent vintage
grywitt
245
Nm
Well the part number on the actual machine is different than the TM I was looking at. I haven't found a source but I'm at least seeing thongs that look right in my search with this part number. I pulled out all 7 lamps and don't see any numbers anywhere.
peapvp
1,688
Basehor, KS
The plaque shows the same bulbs S6SDC as the manual for DS5 to DS7
Toolslinger
336
PA
Lamp is a T-2 Midget Flange. (that's a new one on me...)
Haven't found the lens housing yet...
Here's one of the OEM's you can dive deeper on info there...
peapvp
1,688
Basehor, KS
Is that an assembly? I just ran across this page and scrolling down to the example drawing, it indicates a lamp, lens/housing, and what might be a little o-ring or such...
Dialight used to manufacture all of those Bulbs and sockets
The NSN you posted is for all parts shown on the page a complete assembly
a cousin of those look this here:
DIALIGHT 181-8836-0931-553 INDICATOR LIGHT RED
Dialight now makes only LED based Lights.
The Chinese are now making all the incadecent light bulbs like the ones you got currently installed
peapvp
1,688
Basehor, KS
Do some of you guys have a membership or something to that part target thing or just know how to ask? When it pops up for me it never seems to be so informative. Thank you again
No, just having either the correct NSN or Part Number.
grywitt
245
Nm
Well I'm still hoping to get my hands on some new bulbs and even the housing that burnt up but it's pretty awesome the parts were there to fix it.
2Pbfeet
1,530
Mt. Hamilton, CA
I think a little TLC on the housing and you should be ok.
On your bulbs, is it possible that we you photographed above is a midget light in a dome housing? It looks from afar as if there is a seam, just above the flange base on the bulb. might it come apart there?
Nevertheless, if you can buy the bulbs, I'd go with that if it were me. (Nice find @peapvp!)
All the best, 2PbFeet
grywitt
245
Nm
I ordered 5 of them. Thank you for the help. I really enjoy working on these things and the people on here make it feasible.
