M939A2 starter system dead short. Any help where to start?
20,816
When I turn switch, sparks and smoke from batteries.
Sent from my SM-S921U using Tapatalk
Any chance you might look at the ground strap and ground wires?
Loose grounding will cause what you describe.
Jbulach
2,414
Sunman Indiana
First WAG would be batteries are wired incorrectly. Is this a new to you unknown truck, or this condition started after…?
ericp351
109
erie Pa
Agree with above, and I'd triple check batts AND pull starter hot, hit switch and confirm 24V pos. Lots of power in 2 or 4 batts to risk an acid bath or fire! Good luck.
cbrTodd
508
Indianapolis, Indiana
If it's a truck that is new to you or if there is any question about its engine health, try barring the engine over by hand to make sure it isn't seized or something. A starter trying to turn a locked up engine can do funny things.
