JimC2
- 137
- 43
- Collierville TN
Not fun. I should have them ready to prime by Tuesday.
Somewhere on my never-ending "to-do" list is the installation of an aftercooler/condenser for my compressor, which is a good way to dry out compressed air. In the meantime, I've been getting by OK with a couple of water separators in combination with the relatively dry air in my shop (I have a dehumidifier to help keep my equipment from rusting).But the air compressor doesn't have a water trap, and after a while starts putting enough moisture into the blaster that it clogs the media.
If you're mounting the tires on the original rims, it isn't hard. I've done it by myself seven or eight times. Put just enough air in the tube to keep the boot snugly in place, and then just slide the tire down over the rim. Then install the split ring. If the split rings are still in good condition (which is important for safety), they should snap into place without too much trouble. Take the usual precautions when airing up the tire.I'll let them cure for a couple of days before mounting the tires on the rims. Not looking forward to that; been over fifty years since I last did it.
It's been a while, and I don't recall what I did to get the valve stems through the openings in the rims, but here's a thought: Maybe you could make a valve stem fishing tool by drilling a hole in a valve cap, running a thin cable through it, and wrapping the cable around a handle.The only part that hangs me up on the reassembly is getting the valve stem back out through the hole in the rim. I manage it, but it takes some fiddling and cussing.
