803A trailer mounted power plant. Lamps
peapvp
1,645
Basehor, KS
@2Pbfeet , @grywitt posted this BOM of his plaque in Post #6
The Lights XD51 thru XDS4 and XDS5 thru XDS7 are E type lights, meaning they are of a screw type bulb
the Lights DS5 thru DS7 are the S6S DC lightbulbs with Bayonet socket
According to grywitt, he unscrewed 7 bulbs possibly meaning those are the XD51 thru XDS7?
I don’t think he took out DS5 to DS7 yet.
The best thing would be @grywitt if you could share with us XD / XDS bulbs you removed and what they are
grywitt
184
Nm
Hey. Sorry for the confusion. 4 of the lights are spares and 4 are working indicator lights xds1-4.
Are the ones I've been trying to source. They are 120vac neon lights. I guess I shouldn't have been talking about the non working spare lights to avoid confusing the issue. If you look back through my pics you will see 4 lights with a wire through the whole batch. Well three now since I used one to replace the one that the wire broke off then touched the other side and fried it. You can see the scorch marks .
peapvp
1,645
Basehor, KS
No those are the bigger sync lights. There are two on the front and one on the back of the sync box
Ok, thank you and XDS1 to XDS 4 are the 4 Lights which need new bulbs and XDS5 to XDS7 are the spare bulb holders which are[were] all soldered together with one wire?
grywitt
184
Nm
Green is xds5-7. You can't see one of them in this Pic because it's on the other side of the box facing the other gen. Red is the spare bulbs and I don't believe they are mentioned or labeled anywhere. Yellow is the xds1-4.
grywitt
184
Nm
The part number on the print you posted for xds1-4 is different than the part number on my plaque so I think that's the print for the new version.
peapvp
1,645
Basehor, KS
Ok, @grywitt here is your homework and the best we can do.
Attached is the military catalog from diallight formerly known as Dialco
Go to pages 13 and 14 those are 359 lights,
They changed all the old part numbers in the genset to the new ones in the catalog without having a cross reference table for the old numbers starting with 13
Check all dimensions and voltages etc.
You may just want to replace the current lights completely with new sockets
Good luck
grywitt
184
Nm
Thanks a lot. You've really dig into this matter. If the bulbs i ordered don't fit in those housings I bought i think I might just convert to led. I really want to stay stock but I can honestly probably do better.
