I would like to add some accessories and so far everything Ive been able to purchase is 12v / 24v compatible (LEDs, Bluetooth, amp / volt meters etc).
If I choose to operate only 24v accessories, is it best to pull power from the forward most bus bar "positive " post in the battery box?
Then run that to a power distribution block (with an appropriate breaker near the post)? Or is there a better way to pull 24v?
If I decide to operate in the 12v world - are there any down sides to installing a step-down in a similar configuration as above? But at this point I don't see a real need to use 12v
Also, currently I do not have any wiring attached to the 14V tap on the front of my voltage regulator.
From what Ive read, attaching an appreciate wire from the 14v tap to the "positive" post on the rear battery will help keep the batteries in balance.
Is this really that simple?
