Mep 831A load issues
2Pbfeet
1,465
Mt. Hamilton, CA
Also both injectors looked the same when they came out. Pretty coated in carbon. It's that pretty normal?
Not in my experience. It seems as if your engine is being overfueled.
If it were me, I would go back to try fueling the high pressure pump directly again and see if that improves your load and smoke. If it doesn't, I am starting to wonder if pulling the engine to check the camshaft timing and the rings might be in order. Sorry.
All the best, 2PbFeet
grywitt
184
Nm
It will be a good learning experience. The more I dig into this thing and study the more I learn. It does seem like 1 degree of adjustment isn't leaving much room. This is the one shim under the fuel pump. Soon I'll get set up and start digging in. I'll post pics and I'm sure have some questions along the way.
