Aux Fuel Tank for MEP-803A, Bung Adapter for 3/4" Port?
Mweiss
50
13
New Milford, CT
As it turned out, my search for a 55 gallon oil drum is not turning up any barrels with two 2" ports. The ones local to me have a 2" and a 3/4" port. I need a 2" port for the oil filler as that's what the oil delivery truck needs.
That leaves me with only a 3/4" port to attach the fuel line.
I reckon there might be an adapter for 3/4", but I only found and bought a 2" bung adapter kit online.
Looking for recommendations for hardware to use the 3/4" port for the fuel line. Where to buy, etc.
Scoobyshep
2,354
Florida
I think a NPT nipple will thread into that. an extra thick layer if teflon tape should hold it. I made something similar for a fuel can with a hose fitting and pickup tube.
Mweiss
50
13
New Milford, CT
I was pondering using some type of 3/4" NPT fitting, and then sweat soldering a 3/8" copper tube long enough to reach close to the bottom of the tank. I have access to Home Depot, so whatever I can get from their plumbing aisle is what I have to work with.
I'm thinking that a reducer fitting might work. Something with and opening that can accept a length of copper tubing. Can it be built from typical Home Depot plumbing parts?
Mweiss
50
13
New Milford, CT
You could use a slip through compression fitting with a piece of copper tube, and then put whatever fitting you want on the end.
This is a 3/4 NPT x 3/8 tube, but they come in other sizes.
So if I understand correctly, this has a male 3/4" NPT thread and passes a 3/8" soft drawn copper tubing?
I also found something like this:
Not sure if the top insert is for 3/8". The site sells 1/2" x 1/2" compression fittings and this was a photo of one example they had.
Toolslinger
336
PA
That's the idea. I know you can get a 3/4 npt x 1/2" tube, but I threw out the 3/8 version as I don't think these machine need more than that, and copper ain't cheap... The thing you have to pay attention to is it has to be a slip fitting, and not have a stop like most compression to npt have.
Any plumbing supply that deals with oil boilers will have them available in some form or another.
BeStihl
29
13
Kentucky
I use ULINE barrels I get from work they transfer oil products to my factory in, made of HDPE which has handled diesel for me so far. They have a 2” NPS fitting that fits the military bung that will directly connect to the aux hose. They also have a 2” Buttress thread bung for filling.
Then on the bottom side of the military bung I used a 1/4” NPT male thread fitting x 1/4” compression for the pickup tube. The military makes rigid copper tubes for this but I haven’t been able to find the whole set.
If you already have a barrel with a 3/4” bung, the compression fitting idea inside a 3/4”npt fitting will work for the pickup but I’m not sure how you would adapt the aux hose.
Maybe another 1/4” compression outside the barrel with a female coupling to leave you a female 1/4” npt that you could screw a male AN-5 fitting into. That would allow the sets aux hose to connect.
Toolslinger
336
PA
I've never tried doing a 37 degree on soft copper, no idea if that's "correct" or possible. Worst case is a 45 flare to NPT, and then to 37 degree. The annoying part will be supporting the copper tube. Beyond that, it's just some basic plumbing.
Mweiss
50
13
New Milford, CT
I see lots of plastic barrels for sale on Marketplace, and they have the required two 2" openings, but I'm concerned about the longevity of a plastic barrel. Wouldn't these develop cracks with summer/winter temperature swings?
Yes, figuring out the 3/4" fittings adds complexity. Since I'm not a plumber, the research and trial and error involved in adapting one of these to AN5 fittings seems daunting. If the plastic barrels are safe to use and long-lasting, then that's something I'd consider. I just don't want the possibility of a massive spill.
BeStihl
29
13
Kentucky
I’ll let you know how it goes after this winter. I put a top made from aluminum over the barrel to keep debris and direct sunlight off as much as possible. I’ve read they hold up for a few years and tend to soften with diesel but others say it’s totally fine so I’m not 100% certain how it’s gonna go. On the positive side, Five gallon diesel fuel jugs are made of the same HDPE. But, I do have access to free barrels so I can change out in a couple years.
I started with a metal can but was worried the metal would allow excess condensation on the inside due to being out in the elements but maybe that was just overthinking it.
vrzff
161
33
Mont Vernon, NH
You can probably
Is there a reason to only limit yourself to a fuel drum? 50 -120 gallon fuel cubes come up in my area on facebook for a reasonable price often.
Shit, I see used HHO tanks up for sale ALL the time-- some relatively small ones too. A little fitting change on the valve, and it will pair right up to an aux fuel hose. What I dont know is if the head pressure will push fuel through the aux pump without it running-- though you could easily change that out for a 24v solenoid if it's going to be a permanent installation, gravity is on your side, and you're getting fuel delivery.
Mweiss
50
13
New Milford, CT
I'm in CT and there's nothing like fuel cubes on Marketplace. I've checked. Lots of plastic "food grade" 55 gallon drums and steel 55 gallon drums though.
That Moeller 635022-10 36" Flexible Fuel Pick Up looks interesting. If that's fits 3/4" NPT that's fine. What's the other end fitting type? A bit pricey though, but if it is right for the job, it's a one time expense.
