Hello All
First time posting a question. After owning fixing a deuce (Lot of knowledge gained from this site )decided to buy a LMTV M1078 its 1995 built unit. Had visual issues but started and drove fine. Bought it, got it delivered drove it into the front yard and a day later tried to move the unit to the shed which is on top of a hill truck will not move. Started troubleshooting all the visual issues are coming back to bite me park brake will not release.I'm aware of the common issue with LMTV with check valves and its on order. The previous owner blocked the vent port on the brake valve not sure why and I have a mysterious hose with a valve which I cannot trace back leaking air all time and leaks a lot of air when brakes are released possible connected to something else to vent its soft to the touch and metal wire wrap around it. My question is can any of you can identify and tell me where its going or coming from. I'm reading the TM's it will take me some time before I find it. Any help is appreciated. Thank you in advance. I have attache pics for reference.
