A Tale of Two Fuel Tanks...it's a tankless job
Wreckclues
712
Jefferson, Massachusetts
Long story short, the fuel tank on my M813 rotted out, check out my recent post on "What have you done to your 5-Ton"
Pictured are my old and replacement tanks side by side. The dimensions are the same just the fuel pickup points and plate size are different and there are no vent holes.
What model does this replacement come from?
Can I just drill and thread new vents?
Is there an advantage to having the pickup in the far chamber?
msgjd
4,047
upstate ny
View attachment 952950View attachment 952951
"what's supposed to be here?" : i will have to check my wrecker or the m51a2's to be sure, but that flat boss might be for placing the fitting for the line coming over from the transfer pump on certain M39-series-types that have a pony (reserve) tank on the pass side
"what's this?" : i will look tomorrow, i don't recall ever seeing that dimple before
Wreckclues
712
If there is a part number on the new tank, you can find out for sure what it goes on.
Aside from "DO NOT FILL ABOVE THIS LINE TO ALLOW FOR EXPANSION" There's nothing on the tank.
The invoice from Eastern Surplus lists the National Stock Number as 2910-00-409-4016, Part Number 11648586, identified as coming from an M809 series 5 Ton truck.
Guyfang
27,131
Burgkunstadt, Germany
Below is the information copied out of TM 9-2320-260-24P-1, Figure 59, Item #1.
1 PAOOO 2910-00-409-4016 19207 11648586 TANK,FUEL,ENGINE 78 GALLON.........
UOC:614,620,621,622,625,626,628,629,637,638
Below is the list of UOC's. Compare the numbers in red to the list below, and you will know what trucks used this fuel tank.
Wreckclues
712
Here's the link to the NSN 2910-00-409-4016, Part Number 11648586 fuel tank advertised on Eastern's website.
Aside from the capacity, dimensions, position of the filler hole and fuel gauge sender it looks nothing like the tank I purchased. With that said it was the only 78 gallon tank they still had in stock and I needed a tank even if I have to modify it, but is it a 11648586 tank? :unsure:
msgjd
4,047
upstate ny
I believe Eastern erred in the tank description/NSN. Yours looks like what's on the M39A1/A2 series of trucks.. Sorry i forgot to peek at the tanks on my M62(A2) and the M51A2's .. Hope to remember this tomorrow
I have a 78g tank from an M809-series, though.. It sits unmodified in the bed of a F350 as a long-distance tank.. There is a dent in the exposed side of it, thus not good for a restoration job.. Not sure what we're going to do with the truck yet, but if it sells there is a 50-50 chance the tank isn't going to be sold with it
