m931 break adjustment
allie
20
equinunk pa
is there an adjustment for the mechanical breaks they are not holding .the adjuster on the handle is as tight as it can go
VPed
315
Clint, TX
There is another adjustment at the parking brake, on the rear of the transfer case. There is a long section of threaded rod on the end of the actuator cable with an adjustment nut.
allie
20
equinunk pa
ok i’ll take a look. i’m assuming i’ll need to first loosen the adjustment on the break handle in the cab then tighten that nut your talking about? sound correct? thanks
DeMilitarized
1,114
Gainesville, GA
The cable is just used for a secondary emergency parking brake drum on the transfer case. Your primary parking brake holding should come from the air system dumping the air out of the brake canisters to the atmostphere (intake stack) It sounds like you have a blockage in your air release line that is not allowing your brake chambers to lock back up
allie
20
equinunk pa
hm
hmm any suggistions on where to start? thanks
Jbulach
2,409
Sunman Indiana
The caging bolts should be stowed on the side of the can (circled in red) or missing. If there are threads sticking out of the hole plugged with the red cap (red arrow) then your spring/park brakes are caged and cannot work. The rear 2 axles are the only ones that have “parking” brake chambers.
Jbulach
2,409
Sunman Indiana
Looks like your brakes are NOT caged, so I guessed wrong.
You do not use the spring break override, that button should always stay out except in an emergency/combat situation where your spring breaks are locked and you cannot release them otherwise. If you are pushing that button in as normal operation that would explain why your spring brakes are not applying with your parking brake lever.
allie
20
equinunk pa
ahh ok so this explains when i use the handbreak in combination with that spring override out it then holds
allie
20
equinunk pa
it must have been in when i use the hand break o man i feel dumb lol ok so keep it out then we see if that handbreak works correct?
