Dodge M882
NickP
13
Wisconsin
Hello. I’ve been lurking the forums for a while. I’m a big fan of CUCV’s and M880’s. I figured I would share my current rc build. It’s a work in progress. A few exterior details need to be finished as well as the interior. I’ll share progress as I go.
The chassis is a RC4WD Trailfinder 2 and the body is all 3d printed.
IMG_2110.jpegIMG_2104.jpegIMG_2113.jpegIMG_2105.jpegIMG_2108.jpegIMG_2117.jpegIMG_2116.jpegIMG_2112.jpeg
M813rc
3,928
Near Austin, Texas
Welcome aboard!
That is truly impressive, I could easily have mistaken it for a real truck if I hadn't taken a close look. Excellent work, indeed!
What scale is it?
Cheers
msgjd
4,103
upstate ny
i see you chose the less-common 1976 version .. very nice build ! .. the BO drive light cutout should involve the next tier up on the grille , and what is the cutout over at far side of grille supposed to represent ?
NickP
13
Wisconsin
Thanks!
I put the blackout light how it was in my reference photos
The second cutout is access to the hood lock. I saw a few trucks of this era like this. I figured it was a fun thing to add.
msgjd
4,103
upstate ny
well i'll be ! I have not seen grilles hacked out like that for a hood lock .. :D .. None of the 880's in my units had any locks.. However I have an M880 and M890 in the yard with bolted external hasps for a hood lock, immediately above the grille..
Glad to see you went by photos , i stand corrected, the BO light appeared lower on your model than i recall , even if it is on a '76 grille.. However, upon checking a pic of my 1977's grille just now, the BO light is indeed in center line of headlight , as it appears in your 1976 versions.. You are correct.... carry on ! ;) .. i think this is telling me it's late and time to hit the hay before i open my mouth again :ROFLMAO:
NickP
13
Wisconsin
Haha no worries. And I definitely don’t claim this truck to be 100% accurate in any way. But I did try to add things I saw as lurked the M880 threads. Being new to the military vehicle world sometimes I wasn’t sure what parts should be there and what stuff might have been done after service. And then it also seems that even the military had a fair amount of variation for what they did.
The general look I was going for was an M882 that’s been retired and then restored and modified a bit by a civilian owner. This truck was my main inspiration.
M813rc
3,928
Near Austin, Texas
The issue with the M880 series trucks varying from year to year of production was a lesson hard learned for the military. Logistics were difficult to keep up when different year models of "the same truck" had different parts. That is why the subsequent Chevrolet CUCV trucks were all 1984 models, regardless of year of production.
Cheers
msgjd
4,103
upstate ny
Cheers
parts procurement/stocking for the M880/890-series was also complicated by the existence of near-identical @1973 thru 1976 commercial dodge pickups in the system as well, many having standard trannies
msgjd
4,103
upstate ny
looks awesome! .. just a fyi, and yes it's past my bedtime and very tired but no mistakes this time..
The M880's/890's and even the 4-door 1977-78 D200's & W200's the air force received did not have the AM radio.. Instrument panel is moulded solid in that area..
But don't sweat it, my 1ft-to-1ft scale M880 and M890 both have AM/FM/Cassettes .. :ROFLMAO: .. Their original no-radio instrument panels sit unmolested in storage, replaced by civilian ones
NickP
13
Wisconsin
Yeah when I was building it I was ready to sand off the radio, but then just said screw it, it’s civilian owned. It can have a radio now 🤣
There is no shortage of mistakes on the interior. Another little Easter egg is the speedo goes up to 160mph 🤣🤣
msgjd
4,103
upstate ny
i couldn't see the 160 lol.. and was there ever a 160 speedo in any mopar truck? .. way back when,,, my '71 roadrunner had a 150 (one hundred fifty) speedo and i can tell you 135 was too fast with drums all around and
without power brakes !
NickP
13
Wisconsin
Swapped on some more accurate wheels and tires. Proper 8 lug and scaled closer to a 16.5. I also designed and printed some full float hubs for the rear. The front might get some lockout hubs yet as if it had a part time 4x4 conversion done on it.
And does anyone know where and how the canvas tops were typically stowed on these trucks when not in use?
