P6 thrust bearing dodged a bullet…
AdiBarbu
BC , Canada
Yep, Aluminum… Whats it going to do, void the warranty:) the Allison part looks like a fiber re-enforced thermoplastic, probably popped out of a injection mold machine run by Chinese slave labor for .50 each…
There is nothing I can find in this design that forces the clutch carrier back against the bushing. I think it only experiences casual intermittent contact…
Since the pressure lubricant flows in from the rear, around the end of the center shaft(past its bushing) and out the front of the center tower alongside the center shaft, the new thrust bushing that rests right at the front of the center tower is basically under a waterfall of lube oil. In fact when the center carrier race slides back to contact the bushing, the bushing will basically be pressure lubed as that space where disc carrier race contacts the thrust bushing is the only real way for the pressurized oil to leave the center tower except perhaps along the shaft splines… it will now be forced toward the oil notches/passages to be spread between thrust bushing and disc carrier race.
pretty certain it will last longer than I do:)
As for dimensions, well Allison was kind enough to provide the new bushing thickness, 8.5mm or .335”, in the second bulletin. Also that it is 4.9mm thicker than the original which was ~3.5mm…. The roller bearing is 1.992ID and 2.862 OD, but I am machining the bush to a slightly larger OD as the races it sets upon appear to be 2.920. so more oil film surface area to spread out the load.
only partial extra points as I can find no alloy stamps on the piece of 1/2” plate I have available… it drills and machines easy enough so it is not one of the harder alloys, but not as soft as plastic… I might be more concerned if there was some active load on this bearing and there wasn’t so much lube available. I do not expect much wear…
So a "washer" 0.335" thick with an ID of 1.992" and OD of 2.920" instead of that bearing ? Thanks
Ronmar
8,389
Port angeles wa
You can get aluminum bronze plate 3/8 x 3 x 6(enough for 2 bearings) from Grainger for ~100… There are also a couple of marine thrust washer suppliers that make close dimensions 1-3/4ID to 3” OD but nothing that thick. They could be stacked and sweated/soldered then machined to the correct dimensions. The only critical one is the 1.992ID to create a tight fit on the center tower…
AdiBarbu
BC , Canada
I will have them made out of tuffkast I think. I needed only the dimensions so I can replace in same day. Do you have by any chance a drawing with the original Allison bushing? Maybe some grooves for lubrication in there? Thank you.
Ronmar
8,389
Port angeles wa
No drawing, look back thru the transfer case discussions i linked to on the first page of this discussion. You will find pics of the Allison part there.. There is a single ~.06“ U/V profile channel groove in the middle of the face between the ID and OD (~.06” wide x .06” deep). There are 4 radial V grooves at 90 degree intervals running from ID to OD across the face. These are wider than they are deep ~.2”W x .06”D. This divides the face into 8 curved rectangles. These grooves are on both sides of the Allison part, with the 4 radial grooves offset 45 degrees from one face to the other…
AdiBarbu
BC , Canada
Thank you Ron.
This bushing I draw, looks right to you as dimensions please?PXL_20251007_200427505~2.jpg
CONJIN
122
33
Northern California
I've got some silicon bronze that I could throw on the lathe, but maybe too hard for this application?
