Guys,
My starter started making a grinding sound when starting. The truck would fire right up instantly, but the starter made the screeching/grinding sound for the instant it takes to start the engine. I removed the starter and found a few things that concern me.
First, the mounting bracket was installed but the bolt holding it onto the block was not very tight, just pretty snug.
Second, there was one shim on the starter when the body says it's "no shim".
Third, one of the mounting bolts seemed to have semi-stripped threads, as did the threaded hole.
Fourth, there are marks on the nose of the starter that look like crack, but may be casting marks?
Here are some pics of the flywheel for good measure:
I'm not really sure what to think or where to go from here. Does anyone know of businesses here in Central Texas I can use if I need to replace the starter or have it rebuilt? I'm also wondering where to get new starter bolts and if the questionable hole needs some kind of attention.
Any advice y'all could give me would be greatly appreciated.
