enine oel contamination in diesel
frauhansen
603
switzerland
Hi everyone,
This may remind you of my thread about dirty fuel.
I always had this black slime in my diesel and was convinced that I had filled up with crap and now it was messing up my tank.
Now I have it again, and I can see it when I fill up (a small pool at the fuel nozzle).
With all the anti-diesel fungus I've been pouring in there over the past few weeks, nothing can survive in there anymore.
When I look at it, it's motor oil. But damn it, how did motor oil get into the diesel? It can only have come in via the lift pump.
Or am I wrong and there's an even more common way via the injection pump?
Mogman
10,603
Papalote, TX
Hi everyone,
Motor oil would just mix with the fuel and you would never see it.
If you had bugs and killed them you would still have millions of dead bodies in the tank.
Retiredwarhorses
4,642
Brentwood, Calif
Never seen anything like it, I consider myself an expert on the algae issues and treatment, the application of a good anti-microbial will turn the asphaltine into almost a sand, that will find its way into the filter, that’s why the treatment requires weekly change of the fuel filter till it’s been remediated. I personally replace the fuel tank and all it’s associated parts, as well as a new fuel pump, fuel filter and canister has to be cleaned with brake cleaner, the injection pump is an absolute last resort if the algae has already caused irreparable damage.
Gcelevator
807
Fort Lauderdale, Florida USA
from this point of view... your'r right.
But what is this black mass?!
Probably the diesel was contaminated with something? Paint inside the tank coming off, fuel lines (return) not up to todays fuel standards? And lastly water in the fuel, i had something similar in my MRZR and it was water making it's way into the tank every time we were offroading.
Dieselmeister
312
Flagstaff, Az
Could very well be burnt crap/carbon from the diesel refining process (Sort of like the black soot our engine blowby puts into the lube oil). Remember, diesel is refined at extreme temperatures. While refineries do clean up and filter the diesel, there is always a minute amount of contaminants left in the fuel. I see this in the bottom of all my MFC's I use to store diesel. I have the yellow MFC's, so it's really easy to see. If you get fuel from a high-turnover fuel depot, and frequently drive, you won't see it, since it stays in suspension. If the tank remains still, it will eventually settle out.
glcaines
2,830
Hiawassee, Georgia
To me, that looks exactly like motor oil on your finger, but motor oil should mix with the diesel fuel. Is your diesel fuel in the tank really dark colored, which would indicate that a lot of oil is entering the tank and mixing with the diesel fuel? Your photo looks like it is showing a puddle of oil visible in the filler pipe. Is there some type of return line that enters the tank near or at the filler pipe, so that you are seeing oil that hasn't had a chance to blend with the diesel fuel? If so, I would follow that return line to wherever it originates to see if that is the source.
