Ronbo
- 0
- 0
- Mid TN.USA
I see a few post saying to buy a 24 to 12 volt reducer. I was wanting to put a sterion in my Deuce, Is there a problem with just pulling straight off one battery and using 12 volts from there( fused) ?
You didn't state your load. (how much current, or amps)I have a hydraulic dump bed kit with a 12v pump and have been wondering how best to run the 12v pump on my deuce as well. I know ideally I should have a 24v pump, but I'd like to use what I have if possible. A separate battery that can be charged off the stock alternator would seem to be an easy way to prevent problems.
Headwizard - will your converter work for charging a separate battery that sees this sort of load?
Thanks,
Lance
I have a pierce 10 ton dump kit (NIB). The motor on the pump looks like a starter motor but has no load ratings on it nor in the accompanying documentation for the pump. I imagine that it varies depending on the temperature of the fluid and load on the ram. I don't think this presents a problem if I'm running a separate battery to provide 12v power, as long as the converter can handle enough amps to charge the battery.You didn't state your load. (how much current, or amps)
What it the price?WELL WORTH THE PRICE!
