jatonka
- 87
- 48
- Ephratah, New York
The LD-465-1C makes about 300 Ft.Lbs. of torque, The LDT-465-1c and 1D make about 325 Ft.Lbs. of toque. This may answer your honest question on how much torque do these huge engines make. As far as Horsepower, they are not capable of more than what they already make unless you are not concerned with longevity. You can turn the fuel up, add propane, a second turbo if you are capable, and make maybe 400 horsepower, for about a 1/2 hour. Then you can go get another engine.
Or, you can find a 5 ton multifuel engine, change bell housings, starters, dipsticks, and put it in. Then hold on when you push the accelerator down. This is real power. And Longevity. JT out
