imjustdave
- 0
- 0
- Bonney Lake WA
Hello there.
I am trying to find the Studs that clamp "bolt" this rim together. Im also trying to put a name to the truck these would normally be installed on.
FYI the center section was replaced and had a 8 bolt Unimog pattern installed so if your counting lug nut holes that won't help you but they were originally 10.
stud info
The stud specs are 3/4" NF thread
the overall length is 2.5
the length under the head is 2.25"
the width of the flat on the head is 1"
the knurl is 1/4" long and at a OD of .81
Thank you to every one
stud info
