Cold CUCV
diesel583
N E Okla.
I statred my 1031 contact truck that had been sitting a week, it was 15 degrees. Fired up like it was summer. Been working on 6.2s since they came outlate 1981 I think. If they are in good shape they will start, but the glow plug have to work even in warm weather. And they have to crank at least 200 rpm. Good luck
K45
Statesville NC
You might can try some electric blankets to get the engine bay up in temp and then fire it up, if there is no other mechanical issue. i know it is kinda ghetto route but it something to use in a pinch, in your enviroment I would highly recommend a block heater of some sorts
mangus580
282
Western NY
Does anyone have any advice or experience trying to get a cold, 1987 M-1008 (cucv) started in single-digit temps ??
First of all, this should be in its own thread.
Second.... Do a little searching on the CUCV section.
look for a thread called 'bypass glowplugs' and you will see a video posted of a 1009 starting at 5° with nothing but the stock glow plug system.
It sounds like you have some glow plug problems, and may possibly be not following the starting instructions that should be on the back of your visor.
  • Like
Reactions: FMJ
Westech
CPL
6,104
210
cow farts, Wisconsin
I started my 09 this morning and it was 12*. I do not have a block heater or oil heater in yet and it starts right up. Like right up, no smoke no knocking (bad knocking) just runs great. The glow plugs were all replaced by the military right before I got it. With a up to date glow plug system you should have no problem starting in the cold. I would say you should be safe in the -10* ish range even.
And I know I have talked about just installing a switch for the glow plugs but I tell ya the stock system works so well its worth fixing whats wrong and use it. I had a switch on my old m1009 and M1008 and they did not start half as good as my new 09 with stock system. Im sold on stock.
