My wife's gumbo ROCKS!
kendelrio
9,283
Alexandria, La
But that’s not the point of this thread.
The other day I added reverse facing lights to the deuce (see “European Style Blinker” thread). One of the drawbacks was that the left one flashed in my face and made backing the deuce (tough under best circumstances, what with the green light and all…..) almost impossible.
I was taking a stroll through the woods today kicking leaves and pondering the answer to the question “How do I increase the available light I have to back the deuce with?”
I also was thinking about poor lighting in general behind the deuce. I know these are tactical vehicles, but I also wanted a practical vehicle, you know? Sometimes you need more light to work back there.
While I was pondering, I kicked something buried under some leaves and lo and behold! It was two floodlights from a M809 Bridge truck! I picked them up and was about to throw them away when I realized I had found the solution to both questions!
What I did was drill some 5/8 holes into my mud flap bracket to facilitate mounting the lights. I then cut some pipe the same diameter as the mounting rods to decrease the number of threads on the rod for a tight fit.
After that, I wired both lights together, ran 14 gauge wire through the frame to the front of the truck and came in through the firewall. This wire was spliced to one side of the toggle switch; then I spliced the a wire into the light wire for my right dash light (this ensures the toggle only works when the lights are on) and mounted this to the other side of the toggle. Then I drilled the needed holes to mount the toggle switch on the dash.
(Of course this entire process took about 6-7 hours).
All in all I am pleased with the results. Pics attached!
spentshell
Long Island NY
Nice job with the rear lights, backing up in the dark is always fun. They would come in handy if somebody was behind you with the brights on and if you needed light for working behind the truck , of course.
dlawbrey
Boyce,La.
Must be keeping the gumbo in the big metal crates.:p That is one of those inside questions that nobody but me knows the answer to.
WillWagner
3,150
Monrovia, Ca.
I love gumbo...thought there might have been an invite to your place here! Good job on the lights. I like the use of the original lookin' switch and plate too!
littlebob
26
Baton Rouge LA
I like the lights! Another use might be to flash them when you can tell another vehicle is
approaching your rear too fast on all of the two lanes up there.
littlebob
Big Mike's Motor Pool
those lites are sweet, they are way cooler than my back up lites. i took some tractor lites with the rubber housings and put them on my truck . i made some 4.5" brackets out of flat stock and bolted them into the bumperette bolts so i didnt have to drill any holes in the truck. i then modified the one light so that it didnt ground in the mount. this was so i could wire the 12v lites in series to take 24v. i have a box of packard connecters with a few inches of wire still on then that i snipped off a few junkers. i used one to connect my back up lites into the wire that controls the black out lite ont he driver side rear. now when i want to back up i just click on the black outs since i dont need to see forward when im backin up its no big deal. im not sure if the black out system will hold up to long term use of the tractor lites, so i dont leave them on for longer than i need to
buccaneer
Harrison, Arkansas
Gumbo question
While we're on the subject of gumbo...Where else might one pick up a pair of 24 volt lights for reasonable cost? I think my chances of just finding a pair in the leaves are pretty slim!
I did take note of wiring 2 12 volt ones in series... but if one bulb burnt, the other light would be out of commission... Still may be the best option.
Do big rigs use 24 volt systems?
bigelk50
13
albany, Or
Ha I had to do it. Try Napa. They have lots of "Good stuff" seriously there is a bin in the truck section with 24v lights that are bright and cheap I have used many of them. Also if no 24's are present I know they have twelv's too. Just wire in series
1,158
Where did you get that nifty floodlight dataplate?
Anyone repro 'em?
kendelrio
9,283
Alexandria, La
As far as the toggle plate, that was buried in the mud next to the lights. The beauty of using military lights and mounting everything the way I did is I know some states "dissaprove" of rear facing floods. If called on it, I can always say the military put them on! Not only are they bright, but with the stock housing, they also swivel in any direction I need them. They are both aimed out at about a 30 degree angle from center in order to maximize the lighted area.
