Power Steering Fluid
hobie237
Newark, DE
You can get Dexron II, and yes, it is power steering fluid, but since Dexron III (ATF) supersedes Dexron II applications, either will work. Same fluid is called for in the transfer case.
maritimer
Yarmouth, NS
damn umm silly question what would happen if say sosme noticed his P/S pump was low and instead of using atf topped up with P/S fluid ?
hobie237
Newark, DE
It's fine. It calls for Dexron II, anything higher (the only option being Dexron III) can be added, and obviously Dexron II can be added, much like DOT3 and DOT4 brake fluids can be mixed, or GL-5 can be used in gearsets calling for GL-4, barring sulfer issues with the GL-5 and synchronizers (depends on blend of GL-5, but that's well outside the realm of this discussion).
Rageous
Colorado Springs
If you are going to go through the trouble to pump out the old PS fluid I would go the extra mile and add Mobile 1 Synthetic ATF. It just makes sense.
hobie237
Newark, DE
I'd say that it'd be a bigger issue to track down the leak, so that you don't have to keep dumping fluid into it. PS pump rebuild kits are cheap, so are lines.
devilman96
17
Boca Raton, FL
Your forgetting Dexron VI which replaces Dex3
