Rolling_Eudaimonia
- 2
- 0
- New York State
I think I want to swap out my Multifuel engine for a newer better Diesel engine. Right now the two contenders are the Cat C7 230hp model with 620ft-lbs of torque and the International DT-466 with 255Hp and 660ft-lbs of torque. Of course with this upgrade I will need to upgrade the transmission right now the Fuller 6spd medium duty transmission rated at 860ft-lbs of torque is looking like a nice addition to the entire setup.
I'm just not sure which one I should put my money on. The DT466 is close in size and weight to the original engine. Which is fine but the C7 offers a savings in weight and size that might come in handy with other modifications such as a real cab heater, intercooler and water injection kit. Also I want to run the engine on Biodiesel so that voids the warranty on both engines. So which engine do you think will last longer and be cheaper to fix in the long run?
This project is about 2 years away.
can't go wrong with the cummins or the international. The cat your going to need a radiator and aftercooler for just like the M35A3. Then that means longer and wider hood! I looked into the Cat myself. Mechanical engine you won't have any problems with. It is your truck! You will get more input from everyone.
