Rolling_Eudaimonia
- 2
- 0
- New York State
Nope they are the same basic design just bigger in every respect and with a different gear ratio 6.44 to 1 instead of 6.72 to 1 like the M35's. You could put any gear set you want each of them. Aslo you pressurize the hub if you wanted to. It's not impossible, just not easily done. That would make running in the water easier for either the 5ton or 2.5ton axles. How much water do you plan on running in?
