VIN Info-'You may fire when ready, Gridley.'
CARNAC
The Envelope Please.
724
College Station, TX
I picked up an 818 yesterday out of lansing,
05F 91471 C124 14612,
carc/rebuild 6/92,
thanks
Organization:1075TH OD CO MAINT NONDIV DS Location:MARQUETTE
MICHIGAN
Nomenclature:
TRUCK TRACTOR 5-TON Model:
M818 NSN:
2320000508984 Serial Number:
C12414612 Registration Number:
5F91471 Year of Mfg:
1971 Usage Miles: 6131
Aug 1994
CARNAC
724
College Station, TX
I just bought an M35A2 from 100 Dollar Man in Lucerne Valley CA.,who was a pleasure to deal with, and would like to know the specifics.All the data plates on the interior indicate that it was rebuilt at Toole UT. in 92'.The VIN number thats on a plate on the dash is 0525-11884.While looking for numbers stamped on the frame inside the drivers front wheel well,I found a round metal tag about two and a half inches in dia. wired to a bracket on the frame just above the shock with the numbers J02GF6 then below that is 0525-11884 which is also indicated on the data plate as the VIN number on the dash.I found nothing stamped in the frame.What does this all mean.I will be glad to make the donation I just do'nt know where to go with this.Thanks!
James
Organization:HQ, 116TH CAVALRY BRIGADE COMBAT TEAM Location:BOISE
IDAHO
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 NSN:
2320000771616 Serial Number:
52511884 Registration Number:
4G70170 Year of Mfg:
1970 Manufacturer:
65909 Usage Miles: 5724
Apr97
Sent to Property Office at Gowen Field.
CARNAC
724
College Station, TX
Hello, got my first MV this week,:-D and would like any information you can find.
Door # 04K-90371
Frame # 0525 23061
Contract # DAAE-06-70-C-0001
Stock 2320-077-1616
Truck is a M-35A2 W/O W, purchased from GL. Invoice date is 12/10/2008. Picked up from Army National Guard Base, Norman, OK on 01-06-2009.
Thanks in advance.
Scott Post
Organization:1120TH OD CO MAINT REAR Location:ADA
OKLAHOMA
Nomenclature:
M35A2 NSN:
52523061 Registration Number:
4K90371 Year of Mfg:
1971 Usage Miles: 1515
Info Aug 08
kenzo
England
Hello again CARNAC..... and Happy New Year.
A friend from Belgium has asked about his M816 w/w 5-ton wrecker. There is a clash of Serial Number....
Dataplate says NLO 1XM C127 11525
Glovebox lid says NLO 922
Contract was DAAE06-69-C-0009
AM General Mfr
Chassis number says C340 10219
FSN is 2320-051-0489
Can you please let us know:-
1. Which is the correct Serial Number?
2. What was the date-of-delivery?
3. What was the last unit to use it?
Thanks as always for your help.....
Kind regards....
Ken
CARNAC
724
College Station, TX
AM General Mfr
Kind regards....
Ken
The frame number is always the legal number.
Nomenclature:
TRUCK WRECKER 5-TON Model:
M816 W/W NSN:
2320000510489 Serial Number:
C34010219 Registration Number:
NL0922 Year of Mfg:
1981 Manufacturer:
65909 Contract Number:
DAAE07-79-D-5015
Info Sep 2005. No unit info except for a unit code of W4D115.
So this info is supported by the glove box reg number,
The dataplate is for
Organization:32D SIGNAL BN HHC KELLEY KASERNENomenclature:
M816 W/W NSN:
C12711525 Registration Number:
NL01XM Year of Mfg:
1972 Manufacturer:
65909
INFO FEB 89
CARNAC
724
College Station, TX
I guess that didn't turn out as readable as I thought, Here are the numbers...
1967 M35A2
Serial:12530253
Reg: 4K5426
NSN: 2320000771616
Thanks again
Being able to cut and paste into my search engine is always better than a scan.
Here's what I found.
Nomenclature:
M35A2 NSN:
12530253 Registration Number:
4K5426 Year of Mfg:
1967 Usage Miles: 25359
Indications are it was last used by A Battery, 2nd Battalion, 218th Field Artillery Regiment in Portland Oregon.
Info from Jan 2008
Blythewoodjoe
56
Blythewood, SC
Well let see if I can do this right. I will post what I know here and see if it's enough to determine year of make and who made it.
Data plate contains the following info:
Truck, cargo, 5 ton 6 x6 , M813 wo/w
Fed stock no 2320-050-8902
nothing is stamped on this plate
Another plate states:
Vehicle ser no USMC 514519
repaired (iroan concept) conditon code _
MCLB Albany, Georgia 31704
Date 4 91 odon reading 15902
Bumper stuff:
2320-01-329-7162
Photos of these plates and the bumper are located here:
http://www.steelsoldiers.com/showthread.php?t=27564
I have no other info but I have found some numbers stamped on the frame.
Thanks, Joe.
wsucougarx
65
Washington State
Hello CARNAC, just picked up a dropside deuce today Please provide info
M35A2C
Serial #: 86K1278
VIN #: 0940-10913
The guy said he bought it at Imperial Beach GL around NOV 2005.
CARNAC
724
College Station, TX
Bumper stuff:
2320-01-329-7162
Thanks, Joe.
Unfortunately this is a USMC vehicle. I can only do Army vehicles at this time.
Sorry.
MYAMG
Ellicott City/MD
Carnac, Please look up the following vehicles that I have purchased over the past two years:
# 1) M35A2
Vin/Serial NK05GS
Reg 0540-12148
NSN 2320-926-0873
2) M817 Dump
NL00YJ-72C12311521
Also has a 2081 stamped in a box under the Cont. No. I can't find the NSN #
3) M36A2
Vin/Serial/Reg 0127102044
NSN 2320-000-771619
4) M816 Wrecker
Vin/Serial/Reg NL02711612
NSN 2320-000-510489
5) M36A2
Vin/Serial/Reg NK0CC8-0127-10445
NSN 2320-000-771618
Thanks for your help
coeder
Ohio
You are the best! I am looking for all info for a 5 ton I purchased.
M818
Lansing,MI
Purchased 12/08
2320-050-8984
door 05A85070-C124-10390
DAAED7-83-C-H-479
eng# 11240446
spec# 11664325-1
Wondering the VIN and year of truck and what service it has done. Thank you for the help!:):)
OD_Coyote
58
North Bend, WA
Mr. Carnac - Can you provide the year of manufacture and a brief service history for my newly aquired M35A2C I picked up from Ft. Lewis?
Serial # 0940 10959
Thank you!
Firefighter1303
Decatur TN
Mr, Carnac Can you Please provide me with any Info on a M35 that I recived thru a trade from my Vollie Fire department that I am a Member of. We bought this truck from a large city auction for the bed and poly tank that was mounted on it and for changing the body and tank to another chassis I was given this truck I do know that it is a 1954 Reo all though It dosen't have a door sticker or any thing with a vin, and we didn't get any thing at the auction that lists it either, on the data plates it says Stock Number 2320-835-8463 No Serial Number Reo Model OC-54 DA-20-089 ORD. 8126FS The frame has a number stamped right above the center of the front axle 2793L A35D That is all the Info that I have and I hope that you can help me some. If I get any more Info I will post it. Thank you very Much
OK Mr. Carnac I got a bill of sale from My EMA Director it says that the truck is a Kaiser not a Reo and that it is a '54 with a VIN of DA20089
I have pictures of the truck on thread "Help figure out what kind of truck I have"
atankersdad
15
Glen Arm Maryland
Old wise and knowing CARNAC. father to all MV's. I come to you seeking knowledge on a homeless deuce that has found a home. A good home, with waste motor oil to feed it and a set of solar trickle chargers to keep it ready. It has a big yard to lounge in, that is outside the invisible fence so the dogs cannot pee on. Yes the dogs must guard it but they cannot lubricate the lower portions of its tires. Its a good home for a deuce (right up until Powerhousedeuce gets out his torch and transform it into a 4 wheeler). But that is life. At this stage in it's life a little cosmetic surgery is a good thing. Just look at Joan Rivers!
Here is the info.
Purchased at GL in Mechanicsburg 12/12/08
NSN 2320-00-077-1616
ID# 41207495
M35A2 with whisler, w/o winch
Miles 22800
Hours 550
Thank You
