VIN Info-'You may fire when ready, Gridley.'
Jersey 93 Ty
New Providence, NJ
I'd like to add to the collection of lookups you have going here with both of my newly aquired M1009's. Here's what I have on them:
1984 M1009
VIN: 1G8ED18J1EF1984D6
Model: CD-10516
Stock No.: 2320-01-123-2665
Manufactured Date: 07/84
Registration No.: NF06D9
Bumper Numbers: 42-I-2-113 C-2
1985 M1009
VIN: 1G8ED18J9FF208102
Model: CD-10516
Manufactured Date: 07/85
Registration No.: NF0E95
Bumper Numbers: Covered in Spray Paint
Thank you for your help... I'll make my second SS donaction when I get home from work this afternoon.
CARNAC
The Envelope Please.
697
Corpus Christi, TX
# 1) M35A2
Vin/Serial NK05GS
Reg 0540-12148
NSN 2320-926-0873
Organization:1ST BATTALION, 121ST FIELD ARTILLERY REGIMENT Location:MILWAUKEE
WISCONSIN
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2C NSN:
2320009260873 Serial Number:
54012148 Registration Number:
NK05GS Year of Mfg:
1972 Manufacturer:
65909
Info May 86
2) M817 Dump
NL00YJ-72C12311521
Also has a 2081 stamped in a box under the Cont. No. I can't find the NSN #
Organization:1092ND EN BN CO B DET 1 Location:SPENCER
WEST VIRGINIA
Nomenclature:
TRUCK DUMP 5-TON Model:
M817 W/E NSN:
2320000508970 Serial Number:
C12311521 Registration Number:
NL00YJ Year of Mfg:
1972 Usage Miles: 12715
Info Sep89
3) M36A2
Vin/Serial/Reg 0127102044
NSN 2320-000-771619
Organization:3664TH OD CO MAINT NONDIV DS Location:POINT PLEASANT
WEST VIRGINIA
Nomenclature:
M36A2 W/W NSN:
2320000771619 Serial Number:
12710204 Registration Number:
4K4333 Year of Mfg:
1967 Manufacturer:
65909 Usage Miles: 34330
Info May 2008
You had one too many digits in the serial number. I'm assuming there was an extra 4 at the end.
4) M816 Wrecker
Vin/Serial/Reg NL02711612
NSN 2320-000-510489
Again, this serial number looks jacked up but I think it is this one.
Organization:38TH SUPPLY AND TRANSPORT BN ELECT MAINT Location:INDIANAPO
INDIANA
Nomenclature:
TRUCK WRECKER 5-TON Model:
M816 W/W NSN:
2320000510489 Serial Number:
C12711612 Registration Number:
NL02ET Year of Mfg:
1972 Manufacturer:
65909 Usage Miles: 2046
Info Aug2008
5) M36A2
Vin/Serial/Reg NK0CC8-0127-10445
NSN 2320-000-771618
Organization:166TH MAINTENANCE CO Location:JACKSON
GEORGIA
Nomenclature:
M36A2 NSN:
2320000771618 Serial Number:
12710445 Registration Number:
NK0CC8 Year of Mfg:
1968
Usage Miles: 28848
Info Sep 04
Looks like a nice big chunk of donation:-D
CARNAC
697
Corpus Christi, TX
You are the best! I am looking for all info for a 5 ton I purchased.
M818
Lansing,MI
Purchased 12/08
2320-050-8984
door 05A85070-C124-10390
DAAED7-83-C-H-479
eng# 11240446
spec# 11664325-1
Wondering the VIN and year of truck and what service it has done. Thank you for the help!:):)
Organization:146TH CS BN CO B MAINT Location:STURGIS
MICHIGAN
Nomenclature:
TRUCK TRACTOR 5-TON Model:
M818 NSN:
2320000508984 Serial Number:
C12410390 Registration Number:
5A85070 Year of Mfg:
1970 Manufacturer:
65909 Usage Miles: 13442
Info Sep 05
CARNAC
697
Corpus Christi, TX
Mr. Carnac - Can you provide the year of manufacture and a brief service history for my newly aquired M35A2C I picked up from Ft. Lewis?
Serial # 0940 10959
Thank you!
Validate the serial number. I only have about 50 A2C's in the 940xxxxx serial range with a distinct gap between 94010939 and 94010975.
Many of these late model A2Cs went to the USAF/ANG.
Based on other SN, your vehicle should be a 1986,
jpinst
Hong Kong/Long Beach
Call me a fool, but what exactly are we doing here? Without reading all 71 pages of the post, it seems that members give truck identification and you give history?
BTW, I made a donation a few months ago, and my M35A3 came from the North Carolina Air national Guard and is a 99 model. Do you think there is more to it than that?
CARNAC
697
Corpus Christi, TX
Mr, Carnac Can you Please provide me with any Info on a M35 that I recived thru a trade from my Vollie Fire department that I am a Member of. We bought this truck from a large city auction for the bed and poly tank that was mounted on it and for changing the body and tank to another chassis I was given this truck I do know that it is a 1954 Reo all though It dosen't have a door sticker or any thing with a vin, and we didn't get any thing at the auction that lists it either, on the data plates it says Stock Number 2320-835-8463 No Serial Number Reo Model OC-54 DA-20-089 ORD. 8126FS The frame has a number stamped right above the center of the front axle 2793L A35D That is all the Info that I have and I hope that you can help me some. If I get any more Info I will post it. Thank you very Much
OK Mr. Carnac I got a bill of sale from My EMA Director it says that the truck is a Kaiser not a Reo and that it is a '54 with a VIN of DA20089
I have pictures of the truck on thread "Help figure out what kind of truck I have"
No information on this. A VIN starting with DA doesn't seem right. Everything for M35 in the database is show a 6 digit number or starts with M. There is also a high probability this truck left service before the unit it belonged to converted to managing their records electronically.
CARNAC
697
Corpus Christi, TX
Old wise and knowing CARNAC. father to all MV's. I come to you seeking knowledge on a homeless deuce that has found a home. A good home, with waste motor oil to feed it and a set of solar trickle chargers to keep it ready. It has a big yard to lounge in, that is outside the invisible fence so the dogs cannot pee on. Yes the dogs must guard it but they cannot lubricate the lower portions of its tires. Its a good home for a deuce (right up until Powerhousedeuce gets out his torch and transform it into a 4 wheeler). But that is life. At this stage in it's life a little cosmetic surgery is a good thing. Just look at Joan Rivers!
Here is the info.
Purchased at GL in Mechanicsburg 12/12/08
NSN 2320-00-077-1616
ID# 41207495
M35A2 with whisler, w/o winch
Miles 22800
Hours 550
Thank You
Dudley,
Need you to check the frame serial number. This number isn't bringing anything up.
CARNAC
697
Corpus Christi, TX
1984 M1009
Model: CD-10516
Organization:2D BN 113TH INFANTRY CO C Location:WOODBRIDG
NEW JERSEY
Nomenclature:
TRUCK UTILITY 3/4TON Model:
M1009 NSN:
2320011232665 Serial Number:
J1EF198406 Registration Number:
NF06D9 Year of Mfg:
1984 Manufacturer:
93219 Contract Number:
DAAE07-82-C-4060
Usage Miles: 33273
Info Feb08
1985 M1009
Model: CD-10516
Organization:1ST BATTALION, 112TH FIELD ARTILLERY REGIMENT Location:CHERRY HI
NEW JERSEY
Nomenclature:
M1009 NSN:
J9FF208102 Registration Number:
NF0E95 Year of Mfg:
1985 Manufacturer:
DAAE07-82-C-4060
Usage Miles: 73150
Info Feb1990
CARNAC
697
Corpus Christi, TX
OK, you asked for it. I hereby call you a fool. :grin:
Yep
Nope, it's not Army.
OD_Coyote
58
North Bend, WA
Thank you oh Great One!!!! :not worthy:
It is an ex USAF unit, so I assume that is why it does not register in your crystal ball.
M818Runner
Pittsburgh/Pennsylvania
CARNAC,
Just bought this, new here, maybe you can help...
VIN = C12410180
M818 5 ton tractor
Purchased from GL January 16th, 2009
Purchased from Drexel Gardens, IN
Dont have a Reg # or NSN# yet, trucks still on the GL lot waiting for me :)
Thanks in advance!!
CARNAC
697
Corpus Christi, TX
CARNAC,
VIN = C12410180
M818 5 ton tractor
Thanks in advance!!
Organization:113TH CS BN CO A REAR Location:MUNCIE,
INDIANA
Nomenclature:
M818 NSN:
C12410180 Registration Number:
5A42470 Year of Mfg:
1970 Manufacturer:
65909 Usage Miles: 23339
Info Sep 08
CARNAC
697
Corpus Christi, TX
Matt found the number on the frame. I suspect this is one of the older trucks. Thank you Carnac.
Frame # 114249
I hope that works
See if any of these fit.
008358463 M35142490 4D4709 1961 008358463 M35142492 4D4712 1961 008358463 M35M42490 4A4910 1957 008358463 M35M42491 4A4909 1957 008358463 M35M42493 1953 000771616 M35A212519310 4H4249 1966 000771616 M35A212524249 4H9612 1966 000771616 M35A212534249 4K8919 1967 000771616 M35A232524249 4L83469 1969 000771616 M35A252524249 4N36671 1971 000771617 M35A2 W/W12514249 4G8262 1966 000771617 M35A2 W/W53914249 4N59571 1971
CARNAC
697
Corpus Christi, TX
Uh, that was a nice excel spreadsheet.
Blake
66
Opp, Alabama
VIN info
Carnac,
I am having trouble finding the information on my deuce. It was a depot rebuild and they did not put the vin # on the replacement dash data plate; only the hood number. The hood number is NKOBPM. I think this is 1960's truck due to its box seat and old style taillights. If nothing shows up, I will try and chip paint away on the frame to find the vin.
thanks!
CARNAC
697
Corpus Christi, TX
I`ll try to get this right
Frame #0525 22831
inside door & under hood 04K--41871
Bought from private party in TN.
Bought in June of 08
Sign on door from NJNG.
I hope this is what you need
Organization:50TH FINANCE BATTALION Location:LAWRENCEV
NEW JERSEY
Nomenclature:
M35A2 NSN:
2320000771616 Serial Number:
52522831 Registration Number:
4K41871 Year of Mfg:
1971 Manufacturer:
65909
Usage Miles: 15591
Info Mar 07
CARNAC
697
Corpus Christi, TX
Carnac,
thanks!
Here's what I found on that registration number. I would not use this without confirming the number with your frame number. Doors, hoods, and even data plates get swapped as we have already seen from this thread.
Organization:3647TH ORDNANCE COMPANY (MAINTENANCE NONDIVISIONAL DIRECT SUPPORT) Location:BLACKSTONE
VIRGINIA Nomenclature:
M35A2C NSN:
10662 Registration Number:
NK0BPM Year of Mfg:
1974 Usage Miles: 4760
Info Mar 01
