yet one more question on glow plugs, need some fast help
84cucv1ton
New Jersey
finally sold the k5. he bought a new relay, plugs and batteries. even gave me some cash to put them in. it started ok before was not that great but it did start. now 2 new batteries, plugs and a relay. will not start at all!! its 40 something outside too. i checked everything before i turned the key. cranks good and fast. i know its getting fuel. put the new plugs in with anti seize all over the threads, like i was always told to do.
hes going to be here at 6 to get it and i cant get it to fire. im really scraching my head on this one.
any ideas?? any help would be great thanks mike
dmc-4359
Chapin, SC
What is the part/model number of the glow plugs themselves?
//on the off chance you have the wrong ones
edit - Also, how long are the plugs cycling when you start it up and can you confirm that you hear the gp relay on the firewall clicking?
if you haven't already, I'd suggest getting a digital camera and snapping a few under hood shots of anything you have touched as you may find you nudged something and one of the more savvy folks here may pick up on it.
84cucv1ton
New Jersey
plugs are wellman 070. the wait light is on for about 7-8 seconds. relay is clicking. i can take some pics.
not sure if its true but was told starting fluid could blow the head gasket. never used it.
hobie237
Newark, DE
Pull the glow plug card out so that the plugs don't come on, spray some starting fluid in the intake and then see if it fires. If it does, you are more likely to have a fuel issue than a glow plug issue.
The warnings about not using starting fluid are due to the automatic glow plugs. I guess it's easier to put on a sticker about how to never use starting fluid than a sticker about how to pull the card to disable the plugs.
Michael
24
Fulton, MS
Have you confirmed you are getting voltage to the relay and that the voltage passed through the relay when the key is turned on?
Have you pulled a couple of glow plug wires off and confirmed that they are still good? Easiest way is to pull the wire off and check for resistance.
84cucv1ton
New Jersey
really?? plugs are not even 5 days old. michael, relay is good. power is going to the plugs. whats should the resistance be anyway? i was getting 12v but i could double check the resistance.
thanks
84cucv1ton
New Jersey
to think of it plugs should be on for about 12 seconds right? could you tell me a bit about that? i have no clue how they could be cooked?
doghead
4 Star General /Moderator
1,176
mangus580, right on cooked plugs. 1 stuck, 3 swollen, one has a melted end. now i need to figure out what caused it. :evil:
Interesting, Wellman 070 glow plugs are not supposed to swell.
hobie237
Newark, DE
Three of mine did. Everybody says they don't swell, but everybody also reports that they do, in fact, swell. That said, none of mine were bad enough that they gave me any trouble coming out.
AJMBLAZER
Paducah, KY
Huh, wow. I had a bunch of dead Wellman 070's in mine last year. Crap covered and definitely dead but none had swelled. Guess I got lucky.
