O-ring please help!!
396sahara
quitman, tx
Okay guys so i have 4--- 5 ton 10 bolt beadlock combat wheels.. I think they are 900 series. 2 of them have really large studs for the outer ring and 2 of them have studs that look like the same studs that are on the 20 bolt rims which are pretty small. The large studded 10 bolt rims have the regular o ring lip for the round o-ring. Now the other 2 10 bolts rims i have do not have any place for an o ring to seat. i heard that some of the rims have a funky triangular shaped o-ring. Anyone have a source for these?
thanks for any help.
Josh
396sahara
quitman, tx
Okay , with a little further investigation they look to be A1 combat rims with the 10 bolt small 5/8 stud. But the thing that still boggles me is that there just seems to be no place that an o ring can go on that wheel and actually seal worth a darn.
any help will be greatly appreciated.. and maybe part numbers if you have them
jwaller
19
Columbia, SC
a little searching on here will net you the answer. I know I went thru this and many others. the part numbers are on here somewhere.
Cdub
New Milford, NJ
If my memory is correct...........
A1's.....smaller studs the wheel slips over the side of the O ring
and the
A2's.....the larger studs the wheel sits on top of the O ring which makes them look like a triangle when removed.
I think the only difference between the O rings is the diameter.........I'll try to search for the threads that were started here before which may expalin in greater detail.
either of these two companies may have both types
http://www.easternsurplus.net/
http://www.memphisequipment.com/
seya,
C'dub
