There is an English manual for the 813. I know this because I have run across it in my search for one for the PV3S which my truck is built on. I have the english manual for the PV3S as well as the Czech and I would recommend that you have both on hand as well because the Czech manual has much better and more detailed illustrations and goes more into the specifics of what you can use as well as alternatives. Also there is more multifuel specifics in the original Czech version that you can translate and find out.Ha, got it to run today. Start pilot did it. Well, there's a little tray under the to put some petrol in, and that goes to the air intake near the engine. Brilliantly simple.
Next up is to find out how to switch between high and low gearing, and how to operate the winch
Also noticed some bad air leaks, its building up brake pressure, but the main system (I think thats what the indicator means) doesn't go over 3 bar.
Small (phone quality) movie here
Wow nice 813's guys!
Hey Tatra813, (and other 813 owners too!)
what oil are you putting in your injection pump? Is yours a MotorPal pump with 12 outlets or are you running two 6 outlet pumps?
Here is the IP from my T-912-2 in my Jesterka, I've been putting straight 30HD in it with a tablespoon of Lucas additive.
Running Shell 15-40W in the crankcase with a gallon of Lucas as well.
Whoa! That's getting me lost in tons of czech pages, I found the manuals (I think) but its library references only. Or am I missing digitalized downloads somewhere? Thanks for the tip anyway, all I got so far is offers of photocopies of the manual for about $200.
Big pics on my page (to save upload and bandwidth on here):
http://www.ladnet.org/~dunc/tatra/
Im still trying to start the thingGot some smoke coming out of the exhaust but diesel is not igniting. I located the pre-heater switch but it does nothing as far as I can see. Maybe someone can explain their starting procedures to me?
Quoted for truth!One more thing the fuel tanks tend to rust from the inside out and be paperthin and may burst at any time. Ive heard some bad stories, mine all are fine but check it out just in case.
