dm22630
- 42
- 0
- Front Royal, VA 22630
I come up with good (CHEAP) ways to fix things on deuces from time to time....so here is my project today.
Today I fixed the worn out passenger bench seat in one of my deuces. Very simple fix & can be done with simple hand tools.
Fix Time = 2 hours
Cost = FREE
Parts needed:
a) Two (FREE) foam couch cushions
b) New rope/phone wire (to secure canvas, the old rope will be worn out).
I pulled the bench seat out to do this, however, that is NOT required & would be easier to do if I had left it in place.
Step by Step below.....
1. Remove both seat cushions from the truck (they are held in place by cotter pins).
2. Seperate canvas cover, padding, base/springs from seat cushion.
3. Cut two standard foam couch cushions in half using a razor blade (MUCH easier with two people).
4. Lay the two halfs side by side, set the deuce cushion frame on top & trace with a marker (leave 1" extra of cushion all the way around).
5. Cut foam to fit & place inside of the canvas cover.
6. Place cushion frame on top, fold edge of canvas over top of the frame, tie with new rope/wire.
7. Reinstall "new" cushions in your deuce & enjoy!
DONE!
Fix Time = 2 hours
Cost = FREE
Parts needed:
DONE!
