Need engine rebuild kit om352
tennmogger
541
Greenback, TN
vtunimog
Vermont USA
OM352 Parts
Jim Ince, at Eurotech is very good, Sean at EuroTruck has a really good parts department and seems to be building continually. Contact Steve Dempsey parts@eurotruck-importers.com.
Other parts sources are Scott at Expedition Imports (not sure on his stock of rebuild kits). Expedition Imports Corporation Home
I use Unimog Canada for some of my parts needs, some folks have trouble with Hans (Hans Mross) but I have always had good luck. His prices are decent and delivery times are better than Europe.
if you don't mind shopping across the pond and paying freight Atkinson VOS has a top notch parts department.
Freightliner is also another source, although you will get much better service from Jim, Sean, Scott etc than from them. The OM352A was put into many trucks and applications. Rebuild kits based upon your engine No. should be relatively easy.
