Thanks to all! Problem fixed,started with fuel filters .Primary fuel filter housing gasket was mostly "inside" the housing no idea how this did not leak.Changed secondary filters as well, next day still poor start!
Went to checking every fitting (there was no leakage at any time) ,vent and "by -pass "on top of secondary filter housing were both not very tight, next day
. Went to "check valve/disk "? on bottom of inj. pump ,hard to get to,next day
Finally I went to the flexible line from primary filter to bottom of inj. pump.This line has "Push Loc"? fittings I put two ss clamps on this line,net day
. Thanks again!!!
I have been trying to find secondary fuel filters that have the correct gaskets.Wix 33540 and Luber Finer L540F filters fit but gaskets do not.
