84cucv1ton
- 0
- 36
- New Jersey
just thinking about it. im pretty sure its just for emissions. do you really need it? thanks
Yes, emissions is a part of it. It's a crankcase decompression regulation valve, which means is much more the equivilant of a PCV valve (positive crancase ventilation valve) in a gasoline engine (not the EGR mentioned earlier). It keeps the blowby out of the atmosphere for the EPA, and off of the underside of your truck for you, but also just like a PCV valve it slows or stops external oil leaks and protects your engine oil from excessive contamination from the blowby that is actively scavenged instead of passively vented.just thinking about it. im pretty sure its just for emissions. do you really need it? thanks
