JeremyB
- 1
- 18
- Lake Mary , FLA
I was wondering if the M35 with the Whites have Glow plugs? Every other Diesel that I own have a button or toggle that I use to warm them up.
I was just wondering.
Thank you,I have been jumping around with my reading of the TMs.There could also be an ether start kit installed instead of the flame heater.
Either way, grab the tm's and start reading in your spare time. You'll be glad you did.
You might be suprised,It went down to 9 degrees here in early Feb.There are no glow plugs, but there is a "flame heater" in the intake manifold. Fuel is sprayed into the intake manifold and ignited to heat incoming air. There should be a momentary toggle switch and an instruction plate to the left of the steering wheel. You should not need to use this very often (or ever) in FL. I have never really needed it here in MD.
